Grounds starting to rust
I hit mine with plastidip.
i say this is the best choice so if you need to check the ground you don't need to worry about the paint around it
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
Everywhere I look for plasti dip the black is sold out.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Dielectric grease.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I know one thing plasti will not stop rust. I have a old 97 lumina that I drive here and there. It has a few spots of rust. I plasti dipped them and few weeks later the rust came through the plasti dip.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
When I sprayed it you couldn't see the rust at all now this.
54FCC5E5-F982-49C3-B32F-A4FACEE751FE_zps
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
yeah, paint will do the same thing if you spray it OVER rust. The whole point is to spray it before it rusts to prevent it.
Right but his first post said grounds starting to rust what do I do. So they HAVE RUST, and if he now sprays them they will do this^
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
That's why I told him to remove, clean to bare metal again and put back on. Then spray.
