Phaeton Posted February 7, 2014 Report Posted February 7, 2014 Hey guys, I just bought a audio pipe ap30001 (audio poop) Because i heard some good about it. Also, im not able to slap out 1.5k on a amp. So i went to replace my MB quart oa1000.1 and all i smell is burning coils. Now, before i tell you what subs im running, i know deep down inside me that i am a horrible person. I have 4 lanzar max pro's http://www.parts-express.com/lanzar-maxp154d-15-1600-watt-woofer--267-7138 So i know my audio poop doesnt do a full 3000 watts, its rocking a 200 amp fuse so im thinking around 2000 watts clean if clean is possible. Big d wiz did a video on rms and posted on youtube with the 1500, it did 1000 watts, and all the 3000 is two 1500's strapped. So really what im asking is what are some decent 18" subs i can get for a ghetto budget build? i was looking at some obsidians, but they only got 600 watts rms. I also was looking at an RE woofer with 1000 rms, but it seemed like the obi's would have more xmax and more output (im a sucker for high rolls and fat magnets) 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
RooTxBeeR Posted February 7, 2014 Report Posted February 7, 2014 CHeck out soundqubed, or possibly digital designs new series, redline. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
jake297 Posted February 7, 2014 Report Posted February 7, 2014 A couple Soundstream XXX 15" is what I would buy with a ghetto budget
timc31610 Posted February 7, 2014 Report Posted February 7, 2014 One Soundqubed HDC3 or two HDS3's, you would still be underpowering either but would fit a ghetto budget well...lol My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
audiA6_audio Posted February 7, 2014 Report Posted February 7, 2014 Looks like you may have come across a RE SXX 18. They may not have the huge magnet like the XXX series but they keep up with the MX producing even more force with less power. Im sure youve already looked and done your homework, but ill post some specs so that others know what im talking about. Should give a baseline for comparison. heres some specs: Model SXX 10 SXX 12 SXX 15 SX 18 Electrical Q Value -Qes 0.29 0.49 0.55 0.53 Mechanical Q Value -Qms 4.3 4.5 4.3 6.1 Total Speaker Q Value -Qts 0.27 0.44 0.49 0.48 Free Air Resonance -Fs 30.7 Hz 25.1 Hz 22 Hz 33.2 Hz Equivalent Compliance -Vas 21.8 liters 72.9 Liters 209 liters 159 liters One-Way, Linear Excursion -Xmax 22 mm 22 mm 22 mm 22 mm Efficiency -SPL 1W/1m 85.2 dB SPL 88.1 dB SPL 90.4 dB SPL 92.7 dB SPL Effective Piston Area -Sd 310 cm^2 480 cm^2 810 cm^2 1210 cm^2 DC Resistance -Re 1.9 ohm 1.9 ohm 1.9 ohm 1.9 ohm Nominal Impedance -Znom Dual 2 or 4 ohm Dual 2 or 4 ohm Dual 2 or 4 ohm Dual 2 or 4 ohm Thermal Power Handling -Pe(RMS) 1000 W 1000 W 1000 W 1000 W Force Factor -Bl 21 21 21 21
Phaeton Posted February 8, 2014 Author Report Posted February 8, 2014 Looks like you may have come across a RE SXX 18. They may not have the huge magnet like the XXX series but they keep up with the MX producing even more force with less power. Im sure youve already looked and done your homework, but ill post some specs so that others know what im talking about. Should give a baseline for comparison. heres some specs: Model SXX 10 SXX 12 SXX 15 SX 18 Electrical Q Value -Qes 0.29 0.49 0.55 0.53 Mechanical Q Value -Qms 4.3 4.5 4.3 6.1 Total Speaker Q Value -Qts 0.27 0.44 0.49 0.48 Free Air Resonance -Fs 30.7 Hz 25.1 Hz 22 Hz 33.2 Hz Equivalent Compliance -Vas 21.8 liters 72.9 Liters 209 liters 159 liters One-Way, Linear Excursion -Xmax 22 mm 22 mm 22 mm 22 mm Efficiency -SPL 1W/1m 85.2 dB SPL 88.1 dB SPL 90.4 dB SPL 92.7 dB SPL Effective Piston Area -Sd 310 cm^2 480 cm^2 810 cm^2 1210 cm^2 DC Resistance -Re 1.9 ohm 1.9 ohm 1.9 ohm 1.9 ohm Nominal Impedance -Znom Dual 2 or 4 ohm Dual 2 or 4 ohm Dual 2 or 4 ohm Dual 2 or 4 ohm Thermal Power Handling -Pe(RMS) 1000 W 1000 W 1000 W 1000 W Force Factor -Bl 21 21 21 21 Thanks man, i appreciate it. 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
cloud77 Posted February 8, 2014 Report Posted February 8, 2014 The Sx's are nice drivers. If you plug the pole with a compression plug they can cool themselves because the driver has no cooling properties. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
RooTxBeeR Posted February 8, 2014 Report Posted February 8, 2014 The Sx's are nice drivers. If you plug the pole with a compression plug they can cool themselves because the driver has no cooling properties. Woh woh woh, did you just say to plug the pole end of a sub, to help it breathe better? You do know open pole pieces are there as a cooling device. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
audiA6_audio Posted February 8, 2014 Report Posted February 8, 2014 The Sx's are nice drivers. If you plug the pole with a compression plug they can cool themselves because the driver has no cooling properties. Woh woh woh, did you just say to plug the pole end of a sub, to help it breathe better? You do know open pole pieces are there as a cooling device. lol ive never heard of doing such a thing.. would need a whole lot of convincing to make me wanna do something that could possibly destroy a driver.
cloud77 Posted February 8, 2014 Report Posted February 8, 2014 This is how Fi's cooling system works. You plug the inside of the pole and it helps bring air under the VC and out of the holes in the basket instead of it just coming out the rear. I had an SX 15 reconed with Fi soft parts and added this compression plug for 30$ and I threw 1700W at it maintaining good temperatures. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
