At least 2400 RMS amp for pair of HDS3 15's, suggestions?
G-Rad
I am getting a pair of Soundqubed HDS3 15's soon. I need to find a good enough amp to drive these subs that will make them do some work. I don't have all that much of a budget. I was thinking of the BRZ2400's since they do at least close to rated at 1 ohm Not sure if there's anything out there that can get close enough to it, with rated power in it's buedget. I am not afraid of tacking on some extra but not so much extra that it mutilates my financial budget I am blind and don't get to work much, but I save what I can and make it work. Least I am trying to :)
Any ideas come to mind? Thanks in advance!
BASS MEKANIK RECORDS
"Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold!
2007 Ford Focus
(NOTE: My cousin's build I helped him with)
Pioneer H/U
(4) Absolute Dome Tweeters on A & C pillars
Scosche HD683A's in front doors
Fosgate R168x2's in rear doors
SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz
Audiopipe APCL-1800.1D
Q-Mat
Audio Technix 0 Gauge
119aH/850CCA Marine Deep Cycle batteries
YouTube Channel: http://www.youtube.com/DWRhythm
AQ/SQ 2200 used. Should find one for 300 shipped. The BRx 2400 (new model of BRZ) is 275$
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Id take an aq 2200 all day. Could be found for a very reasonable price used.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Yes you are buying budget subs that can handle 2400w. you are on a budget.
Now what is your planned electrical for this said 2200-2400w?
edit: I guess you can buy the subs then get a cheap amp and upgrade everything later if you plan to do so. I would say why not just back down to the 200 series if you don't have a budget to get the proper power to them
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
I run my BRZ2400 on 4 ga wire and stock alt and batt , but I don't drop past 13.5v at full tilt lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Dang, that's really surprising. where are you reading that voltage at?
The amp
My kia gots 150 amp alt and 69 ah battery from factory, and my wire ois ofc stinger. Charges at 14.8
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Well a Q1-2200 is one option I have had in mind.
Probably won't be much on the electrical, 3 or so 100+aH 800+CCA Deep Cycle Marine batteries (I already have two), and I can get them from a battery shop closeby. Plus the Jeep has a 200+A Alt (can't remember)
I don't own the Jeep actually. My friend does, and he is letting me "have it to play with" for car audio. I can't see to even drive a car, but I just enjoy playing around with car audio and have done it for a few years. It keeps my mind off other problems and keeps me happy. Not trying to get overkill loud, but just something to say "Hey I can at least do this... And no one should let their disabilities set them back from doing what they enjoy".
2007 Ford Focus
Pioneer H/U
Q-Mat
^^ I think you would be more then happy with the 2200 or the 2400. Both will do what you want them to. But like I said before I think you can find the 2200 used for 300. And that would be the better amp out if the two. Not much out there for a buget 2400 watt amp. That's going to be under 500$
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
right, but doesn't mean there's not enough room for one more later on down the road if finances allow it :)
2007 Ford Focus
Pioneer H/U
Q-Mat
  • Who's Online   0 Members, 0 Anonymous, 1063 Guests (See full list)
