Bad start to my day :(
Just got a 01 focus from my father in law few weeks back. This morning I go out and start it up come back out 30 min or so later. To find all the oil is on the ground! FML. Not making crazy sounds at all or over heating when I turn it off. But it was lucky to have 1/2 a qt of oil in it. I hope it's nothing crazy. Was not coming form filter and seems to be off the pan. It was fucking crazy cold last night and in the morning when I started it. -12 out with out windshield when I started.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Did he have oil changed lately on it could be someone didn't tightened down oil filter have had this happen before from cheap oil change places. Just putting it out there
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
He is a 30 year machanic, and shop owner of 28 of them years. He just overhauled the motor. It's not from the filter or drain plug. It's in the front if the pan. I'm no machanic at all so I don't know what's going on. I just hope the motor is not fucked now. It don't have no oil at all! But I think it's ok because it was not over heating or making sounds.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Blew the front seal, do you have a block heater for the car when it gets that cold? was it plugged in?
No I don't. I just got the car like 2 weeks ago :(
I'm not a "car guy" I don't even know about plugin it in?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
What oil filter is on it? Valvoline had a recall on a batch of filters, Not sure if its shop filters, or all that they sell. But that i guess over time they will leak. So they have to be over-tightened to seal. Buddy has had a few come back to him where he works, that they were super low on oil. And sure enough that was the issue.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
You have bigger problems than losing oil.
You'll have to find out if the pvc valve plugged or something else that is plugged causing the engine to build enough pressure to blow the front seal or pan gasket.
I would fill it with oil and take it to the mechanic that just rebuilt it and have him see what happened to it and fix it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
The cam seal rolled over. Something about focus doing this when the oil is to thick, and some other shit.. All will be ok, will be in the shop here soon
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
