Anyone use silicone when mounting subs?
JEFFYBOI
Anyone recommend any kind of sealant when mounting your subs in a enclosure? I made my own box and when i mounted the subs i noticed a small amount of air leaking through. It is flush and level and i didn't strip out any screws so it is a very solid clean mount but i still feel air passing through.
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
if you do use silicone, use a small bead on the edge of the wood. apply the small bead first and let it dry before mounting your subs.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
dont use silicone, makes a mess sometimes and makes it a bitch to get out, just go to your local hardware store and get some thin weather stripping, will work easily and wont stick to the wood, along with sealing it well.
I don't know if I would really consider it a gasket but yeah it has a rubber ring that goes all the way around the sub.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
I like the weather stripping idea... clean and easy to work with and should help seal it up thanks guys
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
I used rope caulk which worked really well and you couldn't even see it when the sub was mounted. but it did get a bit messy when removing the subs
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
yea, just get the stuff that's like .25" or 5/16ths that is like .5" wide or a little less.
basically this...
http://www.homedepot.com/p/Frost-King-5-16-in-x-1-4-in-x-17-ft-EPDM-Rubber-Weather-Stripping-Tape-V25GA/100081207
Do you have any pics of the sub? Preferably the "gasket."
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 2395 Guests (See full list)
