Would you use birch or mdf for this box (pic)
mmets
Going to start building a new box next week. Will get some wood Monday at some point I think. I have this design that was done up and the only change with it will be the bracing. 5/8 threaded rod. Four front to back, four top to bottom and one that will go from left to right through the center port. I have read about birch and mdf and dont want the pros and cons. Just wondering what you guys would build this out of. Either way its either 3/4 mdf or 3/4 cabinet grade birch 9 ply, well 9 ply and a half (thats what i was told since the 10th ply is only half the size of the rest)
So birch or mdf on this one here? TIA (DC level 5 15s, 2 5K's)
PortedBoxfor215DCAudioLevel5s-2_zpsd1486
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
I can afford either. Only thing never did a birch box before and am kind of itching to do one but don't want to spend the money just to turn around and end up getting mdf if I don't like it.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
Whats not to like ? dont think there is a sound difference between the two ..i would use birch though
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Depends. If it comes out good I may stain it if I use birch, or at least the port and wrap the rest. MDF will get wrapped.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
The enclosure will already way a quite a bit with the Level 5s mounted up, so I would try to save a bit of weight by using Birch.
Edit: AudioFanatics mentions below that quality Birch will be nearly as heavy as MDF.
04 Honda Accord LX Sedan
Kenwood Excelon X998
XS Power D3400
XS Power D1200
Singer 275A alternator with factory bypass
64 sqft SecondSkin Damplifier
Build to be decided
:peepwall:
If you have never cut birch know that you should cut it face up or the saw blade (table saw) will chip the grain pretty bad. I would go with birch because stained boxes just look much classier to me. Good Luck
  • Who's Online   0 Members, 0 Anonymous, 3268 Guests (See full list)
