What could I expect from this?
SWGAaudio
So I have 2 Sundown SA-8's powered by a CT Sounds 900.1d. I'm planning on putting them in a 1:1 4th order tuned to about 40hz. I was going to put the subs on one side and the port on the other, throw it in the bed, and cut a blow through into the cab of my 1990 standard cab toyota pickup. I got 2 different audio shop owners helping me so i know it will be done good, my question is how well do you think it will sound overall? And do you think it would be enough to compete in anything whatsoever? And another question, how well will the sa-8s respond to frequencies around 20-30hz?
Bass race? Hard for someone to say. Its 2-8s just don't expect to much you know.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
You will just have to wait and see what happens. Build and hope for the best.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
You can easily model the frequency response of that enclosure, that will answer all your questions.
Hell man if you're gonna do a blow through go big. Don't get me wrong, I love those 8s but still, get like 2 sa 15s. They arent that much more expensive, and get 2of those amps,then cut the bed. If you are wanting big bass in a small space then get the 8s.
I made a box for 2 sa8s in my friends 2013 Titan with a SQ1200 amp. They pound for being so small with a tiny box. Yes they work on the lows but you have to remember they are only 8s and have little cone area. They are awesome little subs you will love them.
Sure you can model the freq response but I've its on a vehicle it will change.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
That's why you take cabin gain into account, or as a rough estimate you should know that the lows will be boosted a lot.
To see how the subwoofers behave around 20-30Hz you'll have to model it, eventhough he'll find out it's all box dependant,
As a starter box (you'll build many before you it right a perfect)
1net sealed
2 net ported
50-55hz
50sq" or port or 8" PVC (you could even go as high as 65sq")
  • Who's Online   0 Members, 0 Anonymous, 2853 Guests (See full list)
