can someone build me a box
ally
2000 honda civic
around 2.5 cubes tuned to 34 hz
for a single 12inch soundcubed hds200
max diminsions would be 27 long 12 high 24 wide
Sub will be ran off a 600w rms amp rockford fosgate
Ok so I had to go above 12"H, I almost know you have what I gave BUT recheck that pls, good to rated power, amp subsonic filter to 28 Hz:
Where are you located at? There might be some people close by who could do it for you.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Yeah, type the state you live in and location in the search function and you probably will be surprise that plenty of people live closer to you. And some of them might got the skills to build box! Check it out, man. It did helped me a lot and everything went smooth!
You can just go to a home depot have the pieces cut for free, get some wood glue and screws and join them together, can be done in a few hours, there will be very few people that can't do this.
I wished that would work at my local Home Depot! I have tried several times but the cuts are usually +/- 1/8" and I ended up with gaps. Thats why Im saving for a better table saw...lol
You need to talk to the guy doing the job and explain him why you need cuts to be accurate and hand over some $, that usually helps.
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
