n8ball2013 Posted March 27, 2014 Report Posted March 27, 2014 Actually the head unit pre outs don't put out 4 volt regardless of setting for the subwoofers especiallyIt's how you are able to attenuate and have separate head unit Control. Typically most head units require the sub out to be turned all the way up to output the full voltage on that channel. I'm betting if you took a meter to the real outs with the volume down the output voltage will be lower. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted March 27, 2014 Report Posted March 27, 2014 the dd-1 is supposed to eliminate questions like this.
Kyblack76 Posted March 27, 2014 Report Posted March 27, 2014 shit lol ok cause than it clips at around 35 and when i play the 1khz it doesnt clip at all so just find the average of 35 and 40 sub out, wouldnt see 1k SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted March 27, 2014 Report Posted March 27, 2014 Actually the head unit pre outs don't put out 4 volt regardless of setting for the subwoofers especiallyIt's how you are able to attenuate and have separate head unit Control. Typically most head units require the sub out to be turned all the way up to output the full voltage on that channel. I'm betting if you took a meter to the real outs with the volume down the output voltage will be lower. correct.... EDIT- that said, on my pioneer 80prs, i didnt turn up shit...... saw signal, saw clipping...... and, kept turning the gain up anyway. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
justin0943 Posted March 27, 2014 Report Posted March 27, 2014 mine at 0 so no you don't need to turn the sub lvl up 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Marquisboys Posted March 27, 2014 Author Report Posted March 27, 2014 Soo basically the headunit it set in stone at 4v or little lower no matter what settings i choose to mess with on the deck. And having the sub level up past 0 would be almost like cranking up bass boost creating a dirty signal. Cause with my sub level on 0 i can go to a max volume without clipping and so can the 1khz test tone on my mids and high amp. 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune
Sutliff Posted March 27, 2014 Report Posted March 27, 2014 I've tapped out. Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
justin0943 Posted March 27, 2014 Report Posted March 27, 2014 Soo basically the headunit it set in stone at 4v or little lower no matter what settings i choose to mess with on the deck. And having the sub level up past 0 would be almost like cranking up bass boost creating a dirty signal. Cause with my sub level on 0 i can go to a max volume without clipping and so can the 1khz test tone. on most of new pioneer you can max volume with out clipping but I keep mine at 40 but since I have shitty electrical I keep the volume at 35 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
n8ball2013 Posted March 27, 2014 Report Posted March 27, 2014 Jesus christ I just gave you an entire paragraph explaining it to you. What was so hard to comprehend that you think the exact opposite of what was said THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Marquisboys Posted March 27, 2014 Author Report Posted March 27, 2014 The dd-1 is cool but i think of this shit like if someone has lets say a 4000rms amp and sets the gain so its not clipping that still doesnt mean that with a 2000rms rated sub it will be ok and wont blow on 4000rms. I over power all my equipment but i play it safe when cranking the volume 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune
