port noise
rsfm089
I said from the beginning the design was right it was builder error. I'm just trying to figure out what I DID WRONG.
Yes, just posted that so that others can take a look but as you say you have to find out what is going on yourself, is important to get the problem figured out so that you have no issues in future builds.
I'm sure the wire in your port isnt exactly helping your issue, but I doubt that would cause a noise like you are experiencing.
I want you to check some things for me
1. Push lightly on both of your subs. They should move freely and with no noise
2. Reach in there with a tape measure, check the distance between the back of your box and your port. Basically port width at the bend
3. What's with the tape?
I hate to admit it but I had a shit ton of peel and seal and thought it wouldn't hurt I will never use it again its falling off everything and getting over everything in my trunk. Learned that lesson the hard way
I don't know how to explain it perfect but if u took a high speed fan in front of a port that's what it sounds lime and today after moving a lot of stuff around one of my bends in my port is moving all around u can hear the wood smacking
Like a helicopter.
If you didn't design your box around port velocity you can easily check it by opening all the doors/trunk of you car, play at tuning or slightly lower and crank it up.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Is playing below tuning of the box is port noise also? 5-10hz?
Port noise will be greatest right at the tuning frequency. Above and below that frequency it will decrease.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3326 Guests (See full list)
