Cutting out and bottoming out
Evan12
I just installed my sundown zv4 15 to my Hifonics 2000 amp down to 1 ohm. When I play my songs and turn it up the amp cuts out and the subwoofer bottoms out at a very low level. I'm not an idiot and turn the gain all the way up it's almost halfway up. I'm very confused on what could be wrong
So your gain was set by ear then?
I don't think that sub can be bottomed out very easily, you may be hearing noise from the enclosure itself? Who built it and who designed it? Pictures will help greatly, as well as setting the gain PROPERLY with a tool such as a DD-1 or oscilloscope.
I built it myself. I've built many ported boxes and they all worked out good. Since I'm on my phone I can't add pictures. The dimesions are
19 tall
41 wide
17.5 deep
The port is 3.25 wide and 20 inches long
Without seeing the box, no way can I tell. Dimensions alone will not help in this situation.
That subwoofer should be hard as shit to find a hard bottom. Not impossible, but seems unlikely to me. You can confirm that you set your gains by ear then, right?
Actually if im not mistaken, there is nothing obstructing the bottom of the coil from the back plate except the spider. You may "soft bottom" of too much power. And btw it took me 3500rms clamped to soft bottom a zv4 15 in 4 cubes. I did however have a faulty amp one time, at loud volumes the sub would suck in and play,not really a bottom out "didnt hear no clacking ect" it just sucked inwards like the suspension got forced back. Swapped the amp,problem solved. Do you hear any metal to metal clacking? Or is it like a turbulent rubber paper sound?
With the amp cutting out, I'm gonna go with a bad or loose connection on the ground. The noise you hear from the sub is likely a side effect of the grounding issue.
I think it wasn't set by ear since he hears that the setting is wrong...
I agree that pictures might help, although a video of the problem would work pretty good too.
  • Who's Online   0 Members, 0 Anonymous, 3394 Guests (See full list)
