Hows this setup sound to you guys??
2 obsidian audio 15 d2v3
1 aq2200 wired at 2 ohm
Stock alternator
(big 3 upgrade also)
Stock battery plus a xs power d975
The enclosure is 7 cubic feet tuned at 33 hz
All this is going in a 1999 gmc sierra z71
Anything i should add? Any suggestion is welcome
A stock alt on a 2200 sounds like trouble ahead, there's no details on the box so who knows, mixing batteries is also a controversial practice. I would keep gains low and get a voltage gauge and see how it goes.
I doubt he will get 2200 watts at two ohms. Set up sounds good, try it out if u get too much voltage drop then add an alt. By the way i run obsidian 18s and i love them very clean and have no problems playing the lows.
THE DRIVING FORCE
True the subs are D2, so OP why are you wasting amp power? D2 subs are for 1 or 4 subs. Alt still needed regardless.
For best results, do not mix the two DIFFERENT types of batteries you are speaking off.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Do not mix lead acid with agm batteries. It won't work properly without an isolator. And an isolator is a bad idea to begin with because diodes drop voltage. Just buy two of the same exact batteries.
Do not mix lead acid with agm batteries. It won't work and will cause a fire! Or an exploded battery!
No it wont.
Its just not recommended and may drop the resting voltage of the agm battery.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
What amp are you running on them.. I just want around 600-800 watts on each subwoofer so what amp should i use and im wiring both 2 ohm subs together to make a final 2 ohm impedence
1. You ill be fine on a stock alt with the AQ2200 at 2 ohms
2. Box sounds fine, but finer details of it would be helpful, like port area
3. Mixing batteries is not a good thing, but you can do it, like said, it will drain the AGM down to the wet cells float voltage and shorten its life span.
  • Who's Online   0 Members, 0 Anonymous, 3123 Guests (See full list)
