14v and 16v systems
don't mean to steal the thread, but, ^^ by adding 14 volt batts to your bank would give you more reserve/power than 12 volt batts? ???
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
You have to be careful going to a 14v system, mainly because the vehicles electronics are built to go up to 14.4v or maybe a bit higher, depending on the vehicle.
Your fuel pump won't 16v
some wont
i charge HIGH while demoing.. around 15.2 (external reg) id go higher if i had 14v bats.. but i dont.
daily, i charge at 14
some ECU's dont like some higher voltages.. some cars are fine.....
that, is what google/search/research is for :shrug:
Idk why I said 14v alt, I meant 14v system...post was after a long (4hr) bio class haha. I've been looking on other threads on the forum and saw one a while back with the system voltages and what they need to be charged at so thanks for clearing that up.
Kyle, yeah I see. Like I said long morning. I just wanted to make sure I get everything g stright before I give the guy am answer.
Other than the slight power increase from amps are there any advantages of a 14v/16v system? Also, even on those systems all ground runs to the frame/chassis are okay?
Thanks guys this is really clearing things up.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
I'm running 14v. Whole car sees 16.1ish daily. No stepdowns of any sort. Car cranks over really, really quick. Kinda nice
What car is that in?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I've been running 14 v batts for 4 yrs in my tahoe I usually set charging to 16.1 no issues but airbag light an tranny don't like 17v
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
But you are you.they are they..you push the limits of anything.lol even a used condom
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
