Grounding your amp question.
Simple question for somebody that knows about electrical more than I do.
- ok I lf I have my battery bank close to my amp, is it better I run a ground to my negative terminal on battery to my amp? Or leave it the way I have it, - a 10" piece from amp term. to the frame of truck ?
If your battery is close to your amp, you could just run your ground to the negative of the battery.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
If you will go to the ce autio electric supply section I believe, Snafu and Tony DAmore did a lot of testing on which one was better. Great write up by those two.
If it's easy to do I would try each way and see which way actually holds better voltage.
2009 Chevy 2500HD Crew Cab
Current Set up -
Headunit - JVC 6100BT
Mids/Highs - Sundown SA-6.5 CS x2
- 4 Crescendo pwx6.5's
- 2 Crescendo ft1's
Mids/Highs amps - 2 Sundown SAX100.4 V2
Sub amp - NS-1 V2
Alts - 2 Singer 320a 6 Phase
2 XS D4800 under the hood
2 XS D3100's in back
2 Sundown Team 18's walled
Do both.
EDIT: Read it wrong. Ground to battery, with the battery grounded to the frame. If the battery is close to the amp, there won't be much difference between grounding to the battery or the frame.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
