DylanBunch Posted October 16, 2014 Report Posted October 16, 2014 Just wanna get some info on how different box sizes and port sizes changes playable bandwidth. Also how it affects efficiency 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
zack_e89 Posted October 16, 2014 Report Posted October 16, 2014 in for knowledge, but i would think that would depend on recommended box specs for the driver and how close/far you are from those along with the power received 97 Suburban 8 custom PSI Platform 3 18's
Nightshade Posted October 16, 2014 Report Posted October 16, 2014 I will give you some perspective on the subject. I am going to give an example as it is easier to make the associations that way. Let's say we have a box that is 3 cubes and we start with 25sqin of port. At these specs lets say it takes the ports being 20" long to tune the box to 32hz. Now if you would like the box to play higher there are a couple of things you could do here. First, you could just keep the same port area and length and shrink the inside of the box. This will increase the peak frequency and will make the bandwidth narrower. If you wanted a lower tune and decided that you were going to keep the specs you would increase the box volume. If you wanted to keep the box volume constant at 3 cubes, then you could adjust the port length to longer for lower tuning or shorter for higher tuning. Usually boxes that are tuned lower have a better bandwidth and play flatter across the board. You can also look at it like this if you want to keep the same box volume but increase the port area you will raise the frequency, and if you were to decrease the port area it lowers frequency. There are also a combination of things that you can do to achieve different results. Let's say you are looking for more spl, with the same specs you could increase the port area and adjust the port length accordingly. Most of the time when you have a higher port to volume ratio spl is higher due to the raised tuning, since most people tune lower for listening. You could also increase the efficiency of your output by taking the box and making it larger and adjusting the amount of port area to keep the ratio the same as well as the port length the same. This works better for lower power as the larger box increased the throw of the woofer, allowing it to travel further off less power because in a smaller box due to the smaller airspace the cone does not have as much air to push the woofer to reach xmax. There is a whole lot more but this is a general understanding. I could type for a couple of hours on how to do this or that from what I've learned over the years but hopefully others will also chime in to add on the topic. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Kyblack76 Posted October 16, 2014 Report Posted October 16, 2014 ^^^ jesus, that makes some sense. I am into this as well. Id like Brian to get in here... ill try and see if he will play. That said, My own on goings. My enclosure is incredibly flat. I hear people say, "i run at .5 daily" . Well, you rise like a monster. I am wired "here", and in time, i can find songs i can NOT play, "lows" or running there for 10 or so songs, i will thermal. Running the IMsg, i see im not over one ohm (REACTIVE) for 98% of the playable band (22-50) I also get loud on not much power. I can blow a 50 at 23hz, but only a 54 at 36. Im extremely flat it seems. Running the IMsg it shows im tuned around 31, which i missed trying to tune to 34. That said.... id love to know how, why, what..... in it all. I also understand, EVERYTHING comes into account. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
hoit Posted October 16, 2014 Report Posted October 16, 2014 wow...tuned in for knowledge!! 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
alaskanzx5 Posted October 16, 2014 Report Posted October 16, 2014 If I'm not mistaken tuning will never be correct. I mean sure you can make a box that is 3cuft tuned to 35hz on paper but as soundwaves bounce off bracing, the speaker, or if you glass or paint the inside air flow and density changes and in turn changes tuning all together. You can get close but never dead on. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Kyblack76 Posted October 16, 2014 Report Posted October 16, 2014 If I'm not mistaken tuning will never be correct. I mean sure you can make a box that is 3cuft tuned to 35hz on paper but as soundwaves bounce off bracing, the speaker, or if you glass or paint the inside air flow and density changes and in turn changes tuning all together. You can get close but never dead on. Add a second person, open a door, or window.. Fart, fuck.. open a beer. That said, you DO have to start somewhere..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
alaskanzx5 Posted October 16, 2014 Report Posted October 16, 2014 Hell tuning can change based on how far your sub is traveling. Moves in and out which in return does change box volume ever so slightly. Mounting a sub inverted adds volume even. Cones on subs go inward towards the motor so you gain a slight amount of volume right there while also decreasing the amount of displacement you have. Band with isn't just determined by volume and port area either though. You also have to factor in the vehicle, power, and choice of subs. Box building is tea and error not a dead on science or mathematical formula. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Kyblack76 Posted October 16, 2014 Report Posted October 16, 2014 Ill admit, i have some "what the fuck??" moments on my gear. Running the IMsg, showing impedance,. metering,.. this and that.. I have my own "WTF ?" shit going on..... i do (retards that think your tuned here, with this power there,.... Ill bet my bank account, your wrong on all)] EDIT - LOL, ok,.. not ALL of you. I know some of you, are, beyond DEAD bang.. That said, that isnt my set up..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
