What Causes Clipping ? MP3 Quality
Dragonware
I'd take performance over looks any day. Your enclosure is designed wrong.
Funny how nobody dares to post the results, you need to have quite good equipment to find the difference.(I'm sure more then 99% of the members of this site don't qualify)
Bitrate isn't that important, what is a lot more important is how the music has been mastered in the studio.
I got it wrong, how do I post the result?
If anyone gets that right, it's a guess. I was guessing when I picked one, it was wrong. But if I had picked the right one, it wouldn't have made it any less of a guess.
Plus, the answer doesn't change so I could just go back and copy the right answer after I got it wrong. If he said he could tell a difference he is flat out lying.
AND i just noticed there is more than one example! lol one second...
OK final results: the one I got right is still a guess
Your Results
Tests done: 3
Correct answers: 1
Percentage correct: 33
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Your Results
Tests done: 3
Correct answers: 1
Take a screenshot :)
But for the results to be any usefull you should atleast do it 15 times.
The song quality doesn't effect clipping at the HU level unless the HU is turned up past the clipping point, at which it doesn't matter if the song is clipping or not, the signal will clip regardless. The signal output by the HU cannot exceed 0dB(u), as long as one does not turn it up past clipping. The digital music file cannot exceed 0dB(u). MP3s sound like shit, but that's not your problem.
To me, it sounds like you're either twisting the FOAD tinsel leads to where they're bending and breaking with the cone movement, and/or you're sending a very clipped signal to your amps by way of incorrectly set gains and bass boost.
Cables and wires almost never fail; the terminations do.
I never thought about using plexi walls for the ports. David from PSI said the RE subs I used has floating leads that were not of great wuality and they cound have been to short to begin with.
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
Your Results
Tests done: 3
Correct answers: 1
Only problem is that it doesn't change, the answers are always the same.
F150:
Stock :(
Processor: DSR1
I think he means use 15 songs.. which does nothing as none of the songs have been mastered in a studio. They're all home-jobs by the info the op gave.
Hammerdown... 1%
  • Who's Online   2 Members, 0 Anonymous, 901 Guests (See full list)
