Now here's an amp on my "bucket list" to put on the Amp Dyno...the Linear Power 8002SW. This amp was available from approx. 1991-1997 and sold for $1600. It is a single channel (mono) 800W amp, which is Class AB and runs the full spectrum from 20Hz - 20kHz. Theoretically, you could use 3 or 4 of these amps to power subs plus mids/highs in a high end system.
See how the 20yr old 800W amp performed on the SMD/D'Amore Engineering Amp Dyno!
Watch on YouTube in 1080P
or embedded below:
See my videos on YouTube http://www.willistonaudio.com  Many tests and demos of OLD and NEW SCHOOL car audio gear!
See cool pics on Instagram @oldschoolstereo
Just by glancing ... I'm thinking that this is a stock 8002sw.
I'm thinking the factory modifications done by TIPS can make these amplifiers do more.
Also, I didn't see where you had the feedback circuit hooked up ... May have made a difference.
This amplifier and 4.1hvs are the only 2 amplifiers that were meant for subwoofer only application. So no, I would not consider these full range operation amplifiers. They may work, but they are mono amplifiers and just wasn't used as full range amplifiers.
slightly off topic, but couldn't you use a pair of these, say per door?
or 4 of them, a pair for door mid ranges, and a pair for highs... For complete separation and what not?
These were primarily used as sub driver amplifiers ... Again, not intended for anything else.
Now with that being said ... Just about EVERY other Linear Power amplifier on the market would work great with the application you suggested ...
That's super cool... Been something I would love to try for awhile
