Hi,
I have a question. I'm building a new ported enclosure for my subwoofer and I wanna know what the peak freq is in my car. I will try to determine by ear but just in case I'm wrong I want to check it with a decibel meter.
I've downloaded an app on my iPhone that's pretty accurate but I'm wondering if the mic on an iPhone 6 can pick up frequencies between 30hz-40hz at the same amount of db's because I've seen a graph of older iPhones showing that it drops slowly below 50hz.
Is there anyone who has experience with this or knows if the iPhone 6 mic can pick up 30 / 40hz at 0db?
Greetings
Pretty sure it would only pick up like 80db or so
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
Granite Crystal Metallic Exterior
Inferno Red Interior
5.7 HEMI AWD
LMI Air Hammer Intake
Corsa exhaust
Custom Tune
Yes it won't meassure full db's, maybe 100 max but I will test it just to see the difference between freqs so I'll keep the volume below that point.
It's just that I don't know if the mic cuts off at low freqs. It has to record at 0db between 30-40hz
The microphones on mobiles have nowhere near the ability to measure pressure than spl oriented meters. Hate to burst your bubble.
I've read that some iphone apps (musicsafecheck and safenoise) are accurate to +/- 2db when under 100db but above that it starts becoming pretty inaccurate, if 2db isn't inaccurate enough.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
110dB is maximum on Apple devices. We used my son's iPod for a school project on sound deadening. Put a speaker inside a box and used various insulation and other materials to see which was most effective to build a home music studio.
Was within 1-2 dB of the AC RTA at home, but we played full range music, not 30-50 Hz, sorry Jam.
Static drops are my bag.
I think the better question would be is the iphone accurate on what frequency is being played. even if it could only measure up to 100 db, that can still be very useful information.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I'm not about to blow out the mic on my 6 testing this
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
it doesnt matter if its accurate or not cause even if it was it would be "A" weighted DB not "C" weighted which is more accurate for low freq. even a really good meter that only does "A" and "B" weighted measurement is not going to be accurate measuring low freq.
Thank you guys for your feedback. Indeed it doesn't really matter how much db's I guess cause it's just to meassure the difference between the frequencies.
I'm using the app called 'dB Volume' and it has a function where I can change the Weighting from A,B & C. I don't know what that means and if it has something to do with the software or hardware wether that works or not.
But if you guys say it's still not accurate even though I play at low volume then I guess I can't really rely on it..
I used this box with a different sub in a different car (also small hatchback) in a competition and it gave the same peak at 33hz and 40hz on the Termlab meter, the sub was a 1200 rms kicker and I'm using a 1250rms Havoc now, they were both 15". I can try to test the app but I guess the numbers wont be reliable with all the changes.
So you guys are saying the only real way to check the peak freq is to buy an expensive db meter that's c weighted? (whatever that may be haha)
Thanks!
