Recommendations on front stage
05flareside
I've got a 2005 regular cab f150 with a high performance PSI Platform 2 12 in right at 3 cubes and currently have crappy mids and highs now. I would like to have mids and highs that can keep up (also have good SQ) and wasn't sure to go with a pro audio style or component sets. I plan on getting an amp to power them as well and budget for the amp would be around 300 and around $200 for the mids and highs
For your application ...
In that particular truck you would be good to have a 6.5" coax driver in each door location with some good sound deadning and strong 2 channel amplifier ... Your drivers should be high enough to where external tweeters would not be needed.
More great free advice from a man who definitely Knows what he's talking about.
in that case, have a look into some splits that can be mounted as a coax (KICKER ss series and old school rs6 splits) the external crossover will give you some sort of adjustments you can make to the tweeter.
I would take cableguys advice, he wouldn't tell you to do it if it wasn't going to work out.
I've done JL tr and c2 5x7's in that truck and they sound great. Especially on a amp with some deadening.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Alright now time to search for a set of coaxs. I planned on running a Crescendo 550/2 which does 150 RMSx2 at 4 ohms. Any recommendations on a set of coaxs?
And also I will invest in some deading and do both doors and possible the roof
Fuck coax.never heard a decent set.will everybody trade out comps for coax.....my option.guess if I'm not cableguy shit don't matter follow the heard..
All I'd did was give a suggestion on what I thought would work ... Nothing more, nothing less.
Sorry to offend you brother, I will keep my suggestions to myself from here on out.
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
