no experience with plexi but from all the bills I followed I have seen the kids pre drill the holes (you need to go slow and.keep changing the bit. the plexi kills the bit and when it gets hot it melts the plexi) there's also a glue for it. most paint the corners to cover the glue and screws.
again no expert here, by any means. just sharing what I've seen.
1/2" should be ok for smaller watt subs, but having no bracing.....that scares me.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
You don't need to change the bit the bit needs to cool if you're doing it slow enough it's not much of an issue by slow means slow. When you think it's slow enough go slower.
There is a special adhesive used to bond the acrylic and plexi edges that dries clear if you put it on messy it turns white and looks like ass. In reality the plexi boxes I've seen don't use many screws if any especially at this size.
Gately audio was the first big name in plexi builds in not sure if they are still in business but they did some amazing work
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Hopefully if everything works out I won't use a single screw. The cement I ordered is coming in today. Haven't worked with it before so I'm not 100% if it'll hold everything all on its own. And I think I should get some epoxy to put on the inner edges?? We'll see when I test it out later today
If you haven't already, I'd plan on a window brace inside the box made of plexi for better rigidity. Good luck.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Yeah, you just have to go sloooooowwwwwwww with plexi. Pretty frustrating. Other than that, that adhesive you mentioned should be good. Using 1/2" I would brace if possible. If you would have used 3/4" I don't think bracing would have been necessary, but another window brace shouldn't be too bad and would actually look pretty cool in there.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Dang it Gunnem! you beat me to it. To OP if you can, those would probably be one of the best options for bracing a plexi box while still looking good.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I dont know if you could drill them out and run leds inside and they still work as good bracing
but if you could thatd be awesome
led lit bracing inside a plexi box
spank ass good time
those rods are sick! i looked into them when i built my mustang's box, but decided against it. ive got some very cool ideas regarding them, but i dont know if it will work.
we'll find out soon!
