anyone ever use this deadener
I've heard that fatmat lies about the mega mat and that it's actually asphalt based too.
Aww damn man dont tell me that haha. Well if it is its already on the car and wont be coming off. I would like to find out if thats true or not though so I wont keep saying it is butyl if it turns out to in fact be asphalt.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
you should never have to heat sound deadener... it breaks down the butyl-
you have to heat up vibraflex before applying it (tantric gator skin) other than that you are correct
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Beware of any sound deadening product that measures everything in Mils and comes on rolls, not sheets. Rolls usually means it is roofing material re-purposed/re-labeled for sound deadening).....only the foil should be measured in Mils.
Check out www.secondskinaudio.com for some quality 100% American made butyl rubber deadener.
This^ Dont be fooled by "cheap" ebay deadner. when it takes 3-4 times the amount to achieve the same as a small amount of second skin it ends up costing more, adding weight, and taking way more time to apply
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
I miss the Audio Technix ... Worked really good for me. Should have bought more that what I did when I had the chance.
isn't that the same stuff as CT Sounds deadener? You can still get that.
Note to self ... Check on this later.
Thanks ...
ahh i just seen it adds mass not what you want in a deadner ... look in the s.s section and use the search button plenty of topics on deadner
Adding mass is exactly what you want in a deadner.
Not at all.
Absorbing vibrations is what you want in a deadener, not just adding mass, that is a very inefficient way and doesn't even work as it just changes the peak frequency.
All that a heavy deadener does is slow down your car, doesn't aid in deadener performance.
