Crimp/Solder 1/0 options
Hey guys, its about time I start putting some connections together for my build, but before i start going ham with a bunch of valuable 1/0 lugs and cable, what is the best method for connections, I have soldered 4ga before with mixed results (had to re-solder a few of the wires later on). I have also "poor man crimped" with a vise, works great, looks like garbage! I wish I had access to a hydraulic Crimper but I don't, and my local Acklands-Grainger sells them for $2000+, not really in my budget. I have SHCA closed end 1/0 lugs and am using both SHCA and KnuKoncepts 1/0 cable. What is going to be the best option for me? any input is appreciated, Thanks!
-If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome.
-"No way he's OCD." -said none of the people that know me ever.
04' Suburban "Lucifer" A.K.A #Lucii (Under Construction)
4 10s on 4kW in 6cu net @~28hz
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~
Gutted pipes
96,000 OG KM's (59,000 mi)
-System Removed-
1 10 on 1kW
89' Gen 3 Honda Prelude SI AWS "Odis"
Bone Stock
Possibly going to stance it
Crimping. I liked soldering the 1/0 at first. Then it got to be a pain in the ass doing 20 connections. Love crimping, takes all of 30 seconds to throw a lug on a wire end. arguably a better connection than solder as well.
This is the same one I have......no problems with it so far (couldn't even tell you how many times I've used it).
Singer Alternators
Team Asshole
#anothershittysingerbuild
Okay awesome! Thank you! I have seen those ebay ones before for $50 but i always assumed they were garbage so dismissed them, if people are having good luck with them it might be worth a shot.
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
Gutted pipes
-System Removed-
1 10 on 1kW
Bone Stock
Why is crimping better than soldering,especially on larger cable and how do you use the hydraulic crimper?
Crimping with a hydraulic crimper virtually makes the copper strands into one solid piece of copper. If you were to cut a properly crimped terminal off it would be one solid piece of copper.
  • Who's Online   0 Members, 0 Anonymous, 813 Guests (See full list)
