Who is the best at designing boxes? I want to do a 6th order!
There is nothing enjoyable about enclosure design
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What sort of bandwidth could I expect out of a well designed ported box? I've gotten used to my 4th being able to go from 30hz to 70hz and I'd hate to give up too much of the high end to get further into the 20's.
What subs are you using? How much power?
I have a pair of Fosgate Hx2 12's with PSI recones. So I have no idea what the TS parameters are now lol. I'm giving them about 2000 watts give or take based on box rise.
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
Talk to OG Hunter.. His screen name is Raptorman, and his service is called "EZ DB Designs." Ill let him know of this thread.
Know how to use a tape measure lol
That would be awesome, Iv'e used a tape measure a time or two lol!
Lower your tuning and you will get exactly what your looking for.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
I would think with frankenwoofers with no specific T/S parameters...the design gurus will have a difficult time calculating your exact needs. One of the reasons I opt to buy subs that have parameters posted! Secondly...while I have NO experience with building 6th order bandpass enclosures, I have heard repeatedly that they almost always require further tweaking to truly reach their potential.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
That's what I'm afraid of, I had luck with them in my 4th. It was designed for the original HX2 speakers but the recones did better in it with the same power. So I've hesitated in doing a new box for a year now, if it's not broke then don't fix it sort of thing; but maybe it can work out if enough research is done.
If you are hell-bent on building a 6th order bandpass box, it certainly can be done, but to do it "right" is going to take some effort.
Are the subs you have broke in yet? If they are you could buy a DATS and measure their T/S parameters. With that info it would be possible to at least begin coming up with a design. If they aren't broke in yet, it would be a waste to measure them since the parameters shift so much.
Once you have the T/S parameters you would be able to tell if your subs are appropriate for a 6th order BP or not. Not all subs will work well with that alignment.
Like khinds94 said, designed a ported box with a lower tune and possible some other tweaks should accomplish what you are looking for.
Builds:
You ever consider doing a bass horn? Do you follow Hexi Base at all on youtube? He is doing some crazy ass boxes right now!
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
  • Who's Online   0 Members, 0 Anonymous, 2508 Guests (See full list)
