mhuffman Posted March 29, 2015 Author Report Share Posted March 29, 2015 ill get a pic after work. and I didn't except them to last forever just with the recurring issue I want to know what the deal it. n8ball2013 the amp is one ohm stable.... nice try thought. Link to comment Share on other sites More sharing options...
zwarrington Posted March 29, 2015 Report Share Posted March 29, 2015 I'm assuming the fuse that you are popping is the one on your power wire, and not the fuses on the amps? What size of power wire are you running from your battery to your amp? Where is the fuse installed on that wire and what size is it? How long is your ground wire from your amp and can you take a picture of where that ground is bolted to? Link to comment Share on other sites More sharing options...
n8ball2013 Posted March 29, 2015 Report Share Posted March 29, 2015 If they are 1000bds they are not. If it's a t1000bd it is. So what amp is it or do you not know? You said 1000bd. I owned 4 of them. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Kyblack76 Posted March 29, 2015 Report Share Posted March 29, 2015 If they are 1000bds they are not. If it's a t1000bd it is. So what amp is it or do you not know? You said 1000bd. I owned 4 of them. I though he said a 1000bd. The T will make the difference... good call.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
mhuffman Posted March 29, 2015 Author Report Share Posted March 29, 2015 I will specify once I see it but what I just read on crutchfield says the 1000bd is 1ohm.. once again unless I looked at it wrong or clicked on the wrong thing. it is just shitty 6 guage for now. it will be getting rewired with all 0 soon. and the ground wire is a 4g and is like 16inches long with and has a crimped loop which is attached to the bolt holding my seat down which is clean and goes directly into the body Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted March 29, 2015 Report Share Posted March 29, 2015 Show us a pic of your exact amp. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ImaNoob Posted March 29, 2015 Report Share Posted March 29, 2015 on a side note Ive heard seat belt bolts aren't great grounds... 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here Link to comment Share on other sites More sharing options...
reedal Posted March 29, 2015 Report Share Posted March 29, 2015 on a side note Ive heard seat belt bolts aren't great grounds... Yes. But seat bolts can be as long as there is good continuity. It's what I use for mine, no issues, good continuity. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Miguels Posted March 29, 2015 Report Share Posted March 29, 2015 6 gauge wire might be the issue. specially if its the budget wire. you need 4 gauge or better my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
zwarrington Posted March 29, 2015 Report Share Posted March 29, 2015 If you have 6 gauge wiring what size of fuse are you using? This amp needs a 140 amp fuse. I'm thinking a 6 gauge wiring kit has just an inline 60 amp fuse? Link to comment Share on other sites More sharing options...
