2 toasted rockford amps.. wtf...
mhuffman
I'm assuming the fuse that you are popping is the one on your power wire, and not the fuses on the amps? What size of power wire are you running from your battery to your amp? Where is the fuse installed on that wire and what size is it? How long is your ground wire from your amp and can you take a picture of where that ground is bolted to?
If they are 1000bds they are not. If it's a t1000bd it is. So what amp is it or do you not know? You said 1000bd. I owned 4 of them.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I will specify once I see it but what I just read on crutchfield says the 1000bd is 1ohm.. once again unless I looked at it wrong or clicked on the wrong thing. it is just shitty 6 guage for now. it will be getting rewired with all 0 soon. and the ground wire is a 4g and is like 16inches long with and has a crimped loop which is attached to the bolt holding my seat down which is clean and goes directly into the body
on a side note Ive heard seat belt bolts aren't great grounds...
Yes. But seat bolts can be as long as there is good continuity. It's what I use for mine, no issues, good continuity.
  • Who's Online   1 Member, 0 Anonymous, 1939 Guests (See full list)
