Whats wrong with my system?(power issue)
try plug something into the cig lighter and see if it works, some have lights that are on a different fuse/circuit to the cig lighter itself (if that makes sence)
Yeah make sure your not jumping off the light 12v on the cig lighter as the bulb may be drawing enough to lower the voltage below what the amp can sense.
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
My iphone charger works. its very unusual because ive had this setup for over a year and half
Why not run it from the remote turn on lead of your head unit?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if the cig lighter works.. and you can "charge your ish" with it.. That means its AFTER that.
Find and run a KEY'd on from your fuse panel. If your using OEM source.
This is basic. You just need a "key'd" on. Get away from the cig ligher as a turn on anyway.
i dont want to run off my fuse panel b/c i dont know how i can do it and still keep the fuse cover on it. I have a 2012 camry se and the only thing that turns on with the car (interior-ly) is the cig lighter location unless there is somewhere else i can tap to?
Help Me Locate (PLEASE!)
Thanks in advance :good:
  • Who's Online   0 Members, 0 Anonymous, 3478 Guests (See full list)
