Here is the enclosure details for my three year old SoundQubed HDS312D2's (thank you to Triticum Agricolam after I was having issues getting my design to show response the way I wanted):
What it will look like :)
B7C1A27B-CB56-4CD4-8D9B-B1AD3B4055CC_zps
Torres specs (actual tuning is 28hz)
78310057-BC58-4061-8123-76C4DB4E08FA_zps
Cone excursion
15FF3AE7-DA22-4E9E-B676-416AEB7777E0_zps
And lastly, frequency response
BE7DC359-0FF4-4FB4-9DDD-F53796F1A1DB_zps
Who wants some pictures?
Everyone wants pictures, that's who!
No pictures of the woodwork yet (because who cares about seeing wood being cut?) but I started the day off with taking the amps, battery, and subs and the pre-fab enclosure out. It's like there's a whole bunch of space hiding back there. It was very solemn to do this though.
Old amp rack I designed to fit in the not-as-wide-assed-as-the-Tahoe-Explorer. Monoblock, 4-channel, and battery with some olddddd no-name wires laying about.
E185A445-F44D-41A5-9772-BBCFD8544CF6_zps
I believe I have found the reason for the loss in output I experienced over the weekend. I had two broken screws, and the glue joints on the baffle next to that same sub had separated. After almost four years of having that enclosure, not bad results from that little prefab
03777751-CD2E-41E9-B5C0-008DF45AFB48_zps
My subs are a little dirty, the surrounds are scuffed, but overall I feel like they're in pretty good shape for the abuse I have put them through in three years.
A0C9427F-6C4A-4E91-83AB-D503AD24A3A3_zps
A5B091E9-6255-490B-B816-51BA0AEE6EC5_zps
And this will be my arsenal (excluding mids and highs)
686C175B-BA44-4B5E-BA21-1CC6B3CA70A8_zps
Thank you to n8 and dollarbilz for the AQ amps, priced very well(cheap) for their good condition imo.
That's all I have picture-wise. I made a mistake and wasted some wood by measuring and making the same cuts twice. So I think I'll just make use of the extra port wall and cut it into shape for my battery.
Tomorrow should be the last day for cuts, then it's all sand, glue, and screw.
Slowly coming together. My cuts aren't perfect, so I'm going to have to do some filling in some places, but being this is only the second time I've tried making my own enclosure, first time in 5 years, I'm not too upset about it.
66FD4BBE-5F84-484F-B4D6-9223C9C6FC77_zps
Only cuts left are the sub cutouts on the double baffle. Will the .75" difference between counter sinking the subs and not counter sinking make any kind of difference?
Update time!
Let's get all of those loose boards glued, clamped, and screwed together :)
5A37F08B-1A95-4C48-91BC-F08313965492_zps
D47808AA-7C92-41B1-974D-AFD857406ECD_zps
Andddd my port walls
42E9A5B9-896E-45CA-A104-9B099AE89E84_zps
37A24455-DC65-4BF3-A6C0-77F09AED0772_zps
And now to test fit the double baffle
98AB7332-DF5E-4055-B6FA-C4EB8C3997C8_zps
A28B0265-269C-4536-AE7B-D49F8B2F0C59_zps
I was a little concerned about bracing it, and with more help from Triticum, I decided on this
6EA96B84-86B2-44DC-85E7-2C1F756BBFF8_zps
It looks rough, but it was cleaned up a lot
7C242BA1-F9C4-4827-8ADC-107CFDC7AB5C_zps
2B1A40D5-E745-45D8-BA4C-A26C0D8DA6E8_zps
34CC404D-48DC-4730-9EFF-CEAA7C91620E_zps
Baffle glued and screwed :)
35113F89-C51A-4AE2-9871-611EA2F81E00_zps
Some body filler where it's needed
7E0F52C3-3F64-486A-8624-AA812D161C5A_zps
Edited by reedal
For subwoofer installation and removal, I decided to go with some barbed threaded-inserts and machine screws. It required drilling the mounting holes in the sub larger, but no big deal
8BBC8E25-E306-46DB-8DB3-628700E4382E_zps
E58B9670-B442-4394-B001-47D5A1881CB0_zps
64366D5D-8BB6-4059-AA53-498D3D085B59_zps
For my amp and battery mounting plans, I made a floor out of the plywood that takes up the entire cargo area, and made a little fence for the battery
E737A2C8-6768-4A7A-903F-BA43B7BE112E_zps
D5D3E07E-03E6-49C3-99CF-2E5E52D003AB_zps
I'm going to attach the 3500 to the rear of the sub enclosure, and I felt like the vents on the bottom of the amplifiers don't get enough air flow, so I took some of my scraps/screw-ups and made some raised platforms to mount all of my amps onto.
0BFCB70E-D049-46D9-AAC6-7A816E35D04D_zps
CD305ED1-2BE9-42AD-96A4-E9664ED2936F_zps
13E45393-CE14-466D-9264-18B9E5CDB3AB_zps
0D847196-D2AB-45A3-8FB5-71EEE6321FB4_zps
And my two 200.2's ;)
53163370-A174-4E4A-B5FE-FB966AFEAC7E_zps
7E67BAE1-D0F4-4BEB-848A-703C26805272_zps
Still need to finish the rack for the 90.4, paint it all, and install it. Got some stuff on the way from sky high, and maybe I'll be done by next weekend :rofl:
Edited by reedal
Love the amp rack man.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
