SQL SUB.... dayton ultimax 12 vs alpine type r or s 12....
im building an SQL set up with a single 12 for my daily. im stuck between 2 subs.
dayton Ultimax http://www.parts-express.com/dayton-audio-um12-22-12-ultimax-dvc-subwoofer-2-ohms-per-coil--295-512
OR
Alpine type S or R 12"
R: http://www.alpine-usa.com/product/view/swr-12d4/
S: http://www.alpine-usa.com/product/view/sws-12d2/
i will only be running 500rms for the sub as i plan to get the alpine PDX-V9 amp http://www.alpine-usa.com/product/view/pdx-v9/
ill be running Alpine SPR-60C in all 4 doors http://www.alpine-usa.com/product/view/spr-60c/
ive owned and heard the new type r's before and they are great in a good box but when entering some info into winisd pro it shows the dayton will have a much smoother gain and much better low end compared to the alpine. but reqires a 3.5ft^3 box to do so...
Dayton is orange 3.5ft^3 dual 3" aeros 15.5" long each tuned at 24.9Hz
Alpine Type R is Yellow 2.0ft^3 dual 3" aeros 16.5" long each tuned at 32Hz
Two 3" ports isn't going to be enough port area for either of those subs.
Cabin gain is going to give you a big low end boost so chances are you are going to want to shrink down your box volumes a bit to tame that. I'll post a picture later that shows how you can roughly approximate cabin gain in WinISD.
Builds:
Since you have the model entered, change to the vent airspeed plot, you don't want to be much above 25 m/s at rated power.
Cabin gain usually make almost worthless frequency response plots predicted by software, tale a look at predicted vs actual frequency response inside some vehicle:
with the current design i have for the dayton, winisd is showing a max of 21m/s at 20hz roughtly
Vs. Threads are frowned upon here.
Here is a filter you can add to WinISD to roughly approximate cabin gain:
Like I said, its only a rough approximation, and just how much usefullness it has is up for debate, but I consider it to be better than nothing. The f0 number can be changed based on the size of your vehicle. 60 Hz is usally pretty good for your average size SUV or sedan.
After looking at the frequency responce you are going to get with that sub, I'd probably be inclined to run it in about a 3 cubic foot sealed box with a good amount of stuffing.
Builds:
No vs threads
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 3402 Guests (See full list)
