Really Confused, more power and electrica, and score dropped ?????
matt14
Or new subs.
So you didn't use the same source as before?
source as in cd? I used a cd That alpine408 had the first time. This time was my own cd. Maybe I'll try a sweep again and see
You are getting alot of useful info here, but you're comparing apples to oranges to begin with.
What? I know I'm getting good info. But what do you mean comparing apples too oranges
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Going from 2 3800's wired into the dirt to 4 3800's
im not really expecting much, spite maybe a bit more for my psyclone runs (if i can hold voltage) but for burps, im not expecting much of a change until i work the box over (shrink internal volume, and or open the vent).
Ill be testing with in the week, im 95% sure of it.
TIm went from 2 nendo 5500's at .35 to 2 TFE's at .35 on his mayhems...
He did gain....... a fair amount i might add. Subs still run cool, and he wangs on them for countless songs back to back.
(he and Ray actually piss me off lol..... they have some magic wand up their buttholes or something)
Did a sweep, Peak changed to 44hz. But still doing about the same on the termlab. 147.0... test on music and did something like a 146.8 i think. Voltage was stable 13.1v.
I adjust the gains using the DD1. Used -5db track to set the gain. When I had the old Nendo 3k, set it with the same track -5db. Now in theory if what some of you are
suggesting that Im exceeding the subs limit, creating more heat therefore making the sub ineffeicant.If I were to set the gain on the amp using say 0db track, therefore dropping the power, I would/could get a better number?
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
Possibly, only one way to find out.
You definitely need to lower your gain! Most test tones are recorded at 0dBfs, if played when gained for -5dB heavy clipping is inevitable.
Current setup
DD Z318 Extra Stiff, Kevlar cone, Double top plate x2
Banda Viking 10k x2
5 Banks of Maxwell 2.85v 3400F caps
Build log Termpro Profile
We know, calm down....
