Finding new grounds
I'll see if I can find a deal on a XS battery if not then I'll just order a distribution block from Kevin. I have about 25' of SHCA 1/0 ofc left over bc I just bought 50' of it so I have the wire to run. Now I just need to find where to ground to the frame in the front.
Best spot to ground, a piece of a bare metal that is attached to the frame.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
He doesn't have a frame and thats the same with all new cars.
Unibody.
Alight I'll look at the strut tower tomorrow.
Now when checking the impedance with the DMM what is a tollorable reading. Would say half an ohm be a good or do you always want it at 0?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Ground to shock tower in front and rear thats what i did in my tiburon.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
^Yeah that, especially if you're using something to extend one of your leads all the way up to the front battery negative. Also make sure your probes are sharp and you're getting through any paint or rust and making good contact.
Alright will do. I'm headed out to work on it now.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I spent a while under the hood/car today and think I figured some things out. I looked at the shock tower but the only bolt was on the top and it wasn't a good ground at all. However I did find a part of the unibody that runs front to back so I'll be grounding the front battery to that. I'm still doing two runs of 1/0 to the back and grounding the amps to that. I will be ordering a new set of battery terminals and once that gets here everything will be done.
Strut tower:
078A62A9-3F7C-4CF3-AE46-6C8F2947D7EF_zps
Part of unibody that will be grounded to:
809C749F-F02B-4F47-A9EF-5EECA193CFDC_zps
1C82727A-61B9-4578-9110-6F06AC6C629E_zps
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
