Alternator Whine issue *figured out* UPDATE pg.11
Alright SMD family I done just about all I can think of but maybe yall can see something that i'm overlooking. Here's the rundown and what I have tried. Basicly I am getting a low volume alternator whine, once the volume is turned up loud enough you can't hear the whine until the rpms get above 3k. This is what I have done so far:
1) Plugged an iPod directly into the amp - no whine
2) Plugged an iPod into the RCA's at the HU running to the amp - no whine
Those two test lead me to believe that it is not an amp grounding issue, so must be somewhere near the HU. My factory harness where the aftermarket one plugs into for the radio adapter was a hack job from the previous owner and when I would bump it the whine would get worse so I ran to the salvage yard and picked up a new one and now thats fine. However the whine is still there.
3) I ran a ground from the HU to the battery up front with 16g wire - whine is still there
Could it be the HU preouts are bad? Any advice is appreciated.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Strip the jacket off of some wire and run it around the outer shield of the RCA jacks on your HU. Like this
What HU do you have?
have you tried grounding else where other than the battery
have you checked the pico fuse
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
If it's a pioneer and you posted this I hope you step on a. Rusty nail
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
make sure everything is grounded at one point...amps, head unit etc. It is most convenient to run a ground wire from your amp(s)/rear battery to the front battery negative. This worked for me. I was in your same situation.
cool...
my 22 grounding points to one point...
check..
cool...
check..
I didn't literally mean one point...I meant like ground everything in the front for instance instead of having some things grounded in the front and some in the back etc...
every car is different...but it worked on mine..no more noise
it worked t
cool...
check..
I dont have alt whine..... :unknw:
so.. some in the front? and some in the back?..
got ya
  • Who's Online   0 Members, 0 Anonymous, 1808 Guests (See full list)
