So, I have managed to detach pretty much every point of contact on my roof braces (which is causing terrible flex, and rattling). I have been reading around for suggestions on getting the roof skin re-attached to the braces. Everything I read says that spot welding is not an option, and the only real suggestion I have seen, is to use a Urethane adhesive. If you all could shed some light on a good way to re-attach my roof braces, it would be greatly appreciated. Also, I would love some ideas on how to reinforce the roof once I get the braces back on.
checked in.. im currently in the same position. I was also told to be careful because the rips can start going around the welds..
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
Weld in new stronger cross braces and secondary steel sheet metal over it and fill with expanding foam. That is what my teammate did after his roof started tearing.
To make sure I am reading this right.. Get some sheet metal, place it between the braces and the roof skin, then weld the braces to it?
I had the same issue, I got the cracked roof braced welded back together and then used pl8x to fill the channel in the brace to rebond them to the roof and then used vibraflex over the braces. So far it seems to be holding. Just make sure to brace the parts as they cure.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
no, in the order i typed it....
weld in braces and secondary sheet metal over that....
Weld box tubing or something like it to the roof, then spot weld steel sheet metal over that to recreate a strong flat inner roof skin.
Everything I read, said that welding will cause the paint to do weird things on the outside. If this wasn't my daily driver, I really wouldn't care. But yea, if it is going to cause issues with my paint, I am going to have to go an alternate route.
Bedline your roof after
Used to have a loud truck
I have seen the concrete roof! That's pretty hardcore though!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
welding will cause the paint to burn and peel around the area....however, I don't think he is telling you to weld directly to the roof.
urethane is strong. it holds your glass in. if you prep the area, it won't let go.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
