For some reason even with the AC on in the house, my room just get way too hot, 3 fans, portable air cooler and window open or closed its still far too uncomfortable for me to get a good sleep without waking up hot as shit and pissed off in the middle of the night lol. And it's really not a big bedroom at all.
Last year I went out and bought a portable air cooler hoping that would help, brand is sunpentown I think, but it sucks ass. I would love to just use one of the AC units you hang out the window but my window is right on the walkway up to the front door so that would be pretty ugly to have it there.
Any of you own one that you know works well? I'm sick of sweating my ass of while sleeping! Lol
Any suggestions appreciated!!
had one in our 5th wheel back when I was little. Ran off a standard 15a 120v plugin. 26ft 5thwheel, it made that thing FRIGID inside.
You might want to invest in some more insulation aswell.
Buy something thats 10,000 btu's or more as you can always set the temps higher, but if you get one that's too low it will just be money poorly spent.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
DO you want ugly window or a good night sleep? I had to use a portable unit once when the central air took a shit and a portable unit managed to cool down a 24x16 bedroom. does yours have a a drain and are you draining it so it stays running? Also try getting a unit that has an exhaust that goes to window or else the condenser is just letting all that heat from the coils right back into room and defeats the purpose. hope this helps.
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
double post
Current build
300amp alt
One that's too big will actually not cool as well as one that is properly sized.
I know you obviously can't tell me what temp my room will sit at lol but do You guys think a 10,000 btu unit will be enough or too much for a 15x18 room, As long as it has the exhaust vent for the window?
Was thinking one of these two possibly:
http://m.homedepot.com/p/LG-Electronics-10-000-BTU-Portable-Air-Conditioner-and-Dehumidifier-Function-with-Remote-in-White-LP1015WNR/205649878/
http://m.homedepot.com/p/Haier-10-000-BTU-350-sq-ft-Cool-Only-Portable-Air-Conditioner-with-80-Pint-Day-Dehumidification-Mode-and-LCD-Remote-Control-HPN10XCM/204712072/
This probably wont help you that much but I can vouch for window units.
The bookstore at my uni has no AC, all they have in there is a little window unit running and that place is usually freezing cold. It's a fairly large room as well.
And the trailer my step father rents out to people only has 1 window unit in the front of the house and it cools that entire trailer even in the summertime.
The problem with portable ac units is the part that gets hot would normally be hanging out the window is in the room adding to the heat.
