Need help picking RCA's
So I'm looking to replace all my rca's in my car. I want all to match and one in there is picking up some alt noise. Here's the ones I've been looking at
1. http://www.petra.com/t-spec-v12rca-172-v12-series-rca-cable-17ft.html
2. https://xplicitaudio.com/shop/xplicit-audio-xa2c5m-16-4ft/
3. http://skyhighcaraudio.com/sky-high-car-audio-2-channel-rca-1-5ft/
All are about the same price so that's an issue. I hope this isn't coming off as a vs. thread, just looking for reviews if anyone has used any of these. The first option I can get locally and quickly but if they're not the best option, I'd rather order and wait. Idk a lot about rca technology so that's why I'm asking for help comparing/contrasting.
Thanks for any input!
Doesn't matter.
Could you elaborate as to why? I'm just trying to learn more and I know some people will argue all day about RCAs
No one can hear a difference. Any cable from any well known manufacturer will do the exact same thing. Noise is most often due to the installation/placement of cables rather than the cable themselves. Unless you're getting them from the dollar store they're all the same.
the most important thing you want to actually match is whether or not your RCA's are differential input or coaxial input. If all of your amps are the same brand than id say its safe to use the same RCA's for all, but make sure they are still the correct input type of youll be adding unwanted noise. The first RCA's you noted are twisted RCA's, or Differential input, the other two im pretty sure are Single ended, or Coaxial. So make sure you a getting the correct type, other than that, the brand shouldnt be too important.
and if you dont know how to test to see what type of RCA's you need......
A lot of people aren't going to know which cable they need, given 90% will be single-ended.
Any thoughts of a tester to help people tell the difference easily if the info isn't readily available?
Spoiler: Use a DMM referenced to ground. Probe each conductor of your RCA or HU ouput connection.
Play a test tone at your max unclipped volume.
If you see AC voltage on both conductors, you're differential.
If you only see AC voltage on the center conductor, and not the outside conductor, your single ended.
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
Not all rca's are created equal.
I'll have to test that out. Now I have a:
http://www.sonicelectronix.com/item_68068_RE-Audio-CTX-1600.2.html
http://www.crescendoaudio.com/index.php/products/amplifiers/item/bc2000d.html?category_id=2
and some cheapy 2 channel just for when I play music outside
I hope to upgrade to an AQ3500
  • Who's Online   0 Members, 0 Anonymous, 694 Guests (See full list)
