I will take better pictures tomorrow when there is light outside. Note if you're going to use crossovers on this headunit remember to set everything up as passive. It sounded like shit at first and I realized that the autotune and autoeq messes some stuff up. I'll connect the RTA when I have the box and sub installed. Oh boy this sounds clean. even have the amp and everything turned down.
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
Box Update: 2.75 cubic feet total at 35hz.
Project Build Log
  • 2 months later...
Now for an update. Last Thursday I installed some acoustic foam because someone told me it would help keep rattles down. Not that I had any but overall the sound did change a little bit.
Though it seems these were too thick as you will see in the video update here:
Basically I will do some big changes which is outlined here
Though this is the list:
This in itself is a huge change. The goal for me is to build a beauty panel for the 4500's like this:
(not my box, just a direction to copy) with some Epic Lighting LEDs
Oh and I noticed facebook doesnt like me hotlinking images so I updated all my image links. imgur.com from now on for sure.
Project Build Log
The box looks really good! Shame you didn't varnish that lovely kerfed port ;)
You reckon you'll need rear speakers with all those in the front when your going active and just have a nice front stage?
^^^^This
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Need? haha. You sound like my wife. hahahaha. I dont know what kind of difference it would make. So update: Installed security film, tint, removed the acoustic foam from the headliner. It was too thick.
Ordered a third SoundQubed hdc3 10, XS Power D3100, NVX XSP525, and a second SoundQubed Q4-90. I'm still going to need cable. I will end up buying the new SMD fuse boxes with the volt meter :)
Project Build Log
Jeep On!!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • 4 weeks later...
New Box! The enclosure is 6 cubes of net volume with a triplet of 6" round ports tuned to 38. The enclosure is built for music. The amplifier will be a part of the enclosure for display purposes, so precautions were taken to limit panel flex. The amp surface is double thick and the amp will be mounted with rubber bushings to reduce vibration. A trim panel for the amp must still be fabricated.
  • 4 - HDC310's
  • 1 - SQ4500.1
Project Build Log
  • 11 months later...
Hello,
So rebuilt the front stage, and thought I would share.
Project Build Log
