Smoove Posted November 23, 2015 Report Posted November 23, 2015 Does the Singer 320 use a smaller pulley than stock like Mechman 370? 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Miguels Posted November 23, 2015 Report Posted November 23, 2015 i will measure tomorrow after work.. they look the same to me but it might be a minor difference my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Smoove Posted November 23, 2015 Report Posted November 23, 2015 with my 370 i had to change my idler to a larger pulley. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
dbackfan12 Posted November 23, 2015 Author Report Posted November 23, 2015 I'm fairly sure the Singer Alt does have a slightly smaller pulley than the stock. Orginally I had planned to use a smaller belt but then decided to try to use the stock one first and it fit pretty well, but with all of these problems I'm sure a smaller belt should be the solution. I think I'm going to try and fit a 37' belt on there and just work my way up in length until I find a nice snug fit. Also, the soonest I could probably work on it would be Friday with Thanksgiving work and school all this week, do you guys think the belt should hold up fine for a couple of days, I would really hate to end up stranded.
Rich Schenk Posted November 23, 2015 Report Posted November 23, 2015 Does it slip on start up or only when you have the system on? Or is it only when system is full tilt. Make sure when u our getting belts you have them check to see how long they our under tension not loose cause that makes a Difference. Goto a legitimate auto parts store like Napa or carquest because most places look at you puzzled when u ask them for a shorter belt. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Rich Schenk Posted November 23, 2015 Report Posted November 23, 2015 Sorry to thread Jack but how long does a belt typically last on a high output alternator because mine is starting to slip as well. And our there any belts that stretch out less then others? On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Miguels Posted November 23, 2015 Report Posted November 23, 2015 I buy my belts online. Saved me money Last I paid was $13 shipped for a gatorback that cost $30 at auto zone. What I did was check the stock belt size and got an inch shorter. go to Goodyear website and get the part number to the closet measurement you need. Then use That part number to search the web Stupid spell check my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
SLYentist Posted November 24, 2015 Report Posted November 24, 2015 sounds like belt slip. i had to take away power steering and add an idler pulley for the second alternator to make enough belt wrap. my current belt is a gates and it has lasted more than 10k miles. I keep a backup and the required wrench in my trunk just in case. Cables and wires almost never fail; the terminations do.
Bump4life Posted November 24, 2015 Report Posted November 24, 2015 sounds like your idle problem is because its a 320 and those suck at idle, the alterntor is reaching its turn on speed and thats why you go from battery voltage to charging voltage back and forth. your car idle must be too low and is not turning on. the squeeling at higher rpms is from belt not being tight enough. try a better/tighter belt and see if that solves all issues. you may need to down grade to a 240 small case hairpin to get better idle output Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
magillaru Posted November 25, 2015 Report Posted November 25, 2015 What does your car idle at (not at startup but after driving for 5-10)? Singer Alternators Team Asshole #anothershittysingerbuild
