Wheelz_pitch Posted December 18, 2015 Report Posted December 18, 2015 Mechman, Singer, DC Engineering are all great companies.
arcaudioman Posted December 18, 2015 Author Report Posted December 18, 2015 Ok thanks I'll check them out
SLYentist Posted December 18, 2015 Report Posted December 18, 2015 I have two alts on my 4 banger and it's SLOW at full tilt. just saying. Cables and wires almost never fail; the terminations do.
Tarball Posted December 18, 2015 Report Posted December 18, 2015 With my 2.2l second alt full tilt stalls the engine. Engineered a bracket with some trial and error. Deleted AC to make room. Heat shielded stuff. It adds up quick. I would do it again but if you aren't the hands on mechanical type stick with a good single H.O. in the stock location. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
arcaudioman Posted December 18, 2015 Author Report Posted December 18, 2015 I'm a union ironworker, I put up skyscrapers for a living. I'm pretty sure I could handle the bracket. But I think I'll try to bypass the eld then do single if that works out
Kyblack76 Posted December 18, 2015 Report Posted December 18, 2015 Cutting a bracket is easy. Milled mine out. Getting it to all work, and work for 60k miles is the bitcheapest Again your over dorking this. Put a decent aftermarket in and run a true 6K SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
diegoclass2010 Posted December 19, 2015 Report Posted December 19, 2015 i also say you should be fine with an ho alt, no need for two.. just make sure all you connections are fine and try to find a way to bypass the charging system i run dual alt set up.. 270 & 370 amp's in chevy malibu 3.5L 6 cylinder... when the bass hits you will definitely feel when the alts are spinning and drag the motor down. on a 25 mile speed limit driving around on 2,000 rpms i drop between 1000-1500 rpms depends on the draw. i really have to be around 2500-3000 rpms going full tilt on radio to keep it steady
hdorre Posted December 19, 2015 Report Posted December 19, 2015 Again your over dorking this. Put a decent aftermarket in and run a true 6K Speaking from experience... This x10000 On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
magillaru Posted December 19, 2015 Report Posted December 19, 2015 Like others have said, you don't need dual alts. Waste of time and money. Get an alt from reputable company (there are only two out there I would give my money to), get an agm batt that fits your stock size under the hood and toss a group 31 size batt in the trunk, and you will be more than fine. If youre having problems with the ecm, you can bypass that if you really wanted to but not really needed with what you're running. If you want good idle voltage and idle low, don't be fooled by "get the biggest alt you can fit". Good luck Singer Alternators Team Asshole #anothershittysingerbuild
arcaudioman Posted December 19, 2015 Author Report Posted December 19, 2015 I was thinking a 250 other 270 Amp alternator. With the eld bypass... I only wanted to do dual because I got the second alt for 40 bucks. Which is way better that 500. I also figured it was easier than bypassing the stupid eld
