CleanSierra Posted December 24, 2015 Report Posted December 24, 2015 If you go to the Sundown only page on Facebook, they will advise you that you'll be fine with a single Zv4 series on that power. Probably at half ohm. Also, the sub will likely laugh at that power and want more. Im not the one you want to try to troll. Just a fyi for you.
daimer Posted December 24, 2015 Report Posted December 24, 2015 If you go to the Sundown only page on Facebook, they will advise you that you'll be fine with a single Zv4 series on that power. Probably at half ohm. Also, the sub will likely laugh at that power and want more. And I personally would agree with them If you look at my signature you'll see why. After impedance rise in the OP's case he would be seeing 2000-2500 watts at best, I don't see why the ZV4 or any of the mentioned subs wouldn't handle it. Every one of the recommended subs will do the trick, it's a matter of personal choice. My humble build log: http://www.stevemeadedesigns.com/board/topic/192602-corsa-b-daily-build-with-12-ground-zero-new-box-in/ Single Zv4 Rev.2 15" on a 10k amp: http://www.stevemeadedesigns.com/board/topic/201434-my-reviewtest-of-the-zv4-rev2-15/
boom50cal Posted December 24, 2015 Report Posted December 24, 2015 Sims Audio Solutions TERROR series... guy is putting out some seriously solid products On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
CleanSierra Posted December 24, 2015 Report Posted December 24, 2015 If you go to the Sundown only page on Facebook, they will advise you that you'll be fine with a single Zv4 series on that power. Probably at half ohm. Also, the sub will likely laugh at that power and want more. And I personally would agree with them If you look at my signature you'll see why. After impedance rise in the OP's case he would be seeing 2000-2500 watts at best, I don't see why the ZV4 or any of the mentioned subs wouldn't handle it. Every one of the recommended subs will do the trick, it's a matter of personal choice. If you have to build to compensate for impedance rise, maybe learn how to actually design and build an enclosure? I'm sorry but 4500W to a 1750W sub is straight jackass. This whole "laughing at that power" shit needs to die. The sub is designed to take 1750W daily, it doesn't need more than that to do its job properly. All it does with that extra power is turn it into heat. Heat kills equipment. If you're only getting 2000W from a 4500W amp, learn how to build a better box... Im not the one you want to try to troll. Just a fyi for you.
gckless Posted December 24, 2015 Report Posted December 24, 2015 If you go to the Sundown only page on Facebook, they will advise you that you'll be fine with a single Zv4 series on that power. Probably at half ohm. Also, the sub will likely laugh at that power and want more. And I personally would agree with them If you look at my signature you'll see why. After impedance rise in the OP's case he would be seeing 2000-2500 watts at best, I don't see why the ZV4 or any of the mentioned subs wouldn't handle it. Every one of the recommended subs will do the trick, it's a matter of personal choice. If you have to build to compensate for impedance rise, maybe learn how to actually design and build an enclosure? I'm sorry but 4500W to a 1750W sub is straight jackass. This whole "laughing at that power" shit needs to die. The sub is designed to take 1750W daily, it doesn't need more than that to do its job properly. All it does with that extra power is turn it into heat. Heat kills equipment. If you're only getting 2000W from a 4500W amp, learn how to build a better box... This. OP, what sort of battery bank do you have? I see the 275A in your sig, but going from 2k to 4k is a bit of a jump. IMO, you're looking for a 4" coil. I'm not a fan of the HDCs, but that's simply my opinion. So SSA, Fi, Sundown, older TC Sounds, Tantric SHD (I know I'll get shit, but the motor is damn good, just DO NOT BUY from Murphy, find it used), and a few others I know I'm forgetting. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
Hugh G. Rection Posted December 24, 2015 Report Posted December 24, 2015 After impedance rise in the OP's case he would be seeing 2000-2500 watts at best Are you just fucking pulling numbers out of your god damned ass here, or have you become the first person on this planet to ever figure out how to calculate the reactance of a completed acoustical reproduction system before all of the components are even decided on? Owner of BigAss Ports
daimer Posted December 24, 2015 Report Posted December 24, 2015 Maybe I'm just pulling numbers out of my ass, so I'll stop. Just speaking from my experience, which is nothing compared to yours. No need for harsh comments, I'm just here to learn and try to be helpful from time to time. Apparently I'm not. My humble build log: http://www.stevemeadedesigns.com/board/topic/192602-corsa-b-daily-build-with-12-ground-zero-new-box-in/ Single Zv4 Rev.2 15" on a 10k amp: http://www.stevemeadedesigns.com/board/topic/201434-my-reviewtest-of-the-zv4-rev2-15/
Frank H Posted December 27, 2015 Author Report Posted December 27, 2015 I have a d34 yellow top in the hood and another same battery in the trunk. Didn't get my woofer for christmas so now I'm ready to shop. Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
Massivespl Posted December 27, 2015 Report Posted December 27, 2015 We clamp 3k + to each nsv3 daily. Love these nightshades c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
