Irocthestreetz Posted December 28, 2015 Author Report Posted December 28, 2015 So I got a response back from mechman and he said a 320A Is available bUT won't charge under 1000rpm what exactly does that mean? That for instance if I'm sitting at a light bumping that I will eat the alts reserve then into my battery reserve?
Irocthestreetz Posted December 28, 2015 Author Report Posted December 28, 2015 I ran 8k between my frontstage and subs on my same 240A alt and ~200aH of reverse. Id drop to 11.9, but stay there. At slam fest, i demoed for the greater part of the weekend, and can count on one hand the amount of times i say 11.6 or lower. I wasnt being "careful" either That seems really reasonable for 8k, what brand of alternator did you have?
reedal Posted December 28, 2015 Report Posted December 28, 2015 So I got a response back from mechman and he said a 320A Is available bUT won't charge under 1000rpm what exactly does that mean? That for instance if I'm sitting at a light bumping that I will eat the alts reserve then into my battery reserve? Most idle speeds are 600-800, meaning your alt won't charge at idle (at lights). SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Irocthestreetz Posted December 28, 2015 Author Report Posted December 28, 2015 So I got a response back from mechman and he said a 320A Is available bUT won't charge under 1000rpm what exactly does that mean? That for instance if I'm sitting at a light bumping that I will eat the alts reserve then into my battery reserve?Most idle speeds are 600-800, meaning your alt won't charge at idle (at lights). So a alt like that probably won't do the best around town then? I'm really hoping to find something closer to like 270 or 280 that will do well at idle
gckless Posted December 28, 2015 Report Posted December 28, 2015 No HO alt is going to do awesome at idle, but you should at least be looking for something that will offer some sort of output at idle. See what Mechman can offer you. Singer is good, and DC Power is the best (IMO only. Lol, I'm going to get shit for that, but I believe it.). Oh and I've got runs of 1/0 OFC, both KnuKonceptz and SHCA. I need to pull them out and measure them, but they are terminated and techflexed. If you're interested, I'll beat the welding wire price. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
Kyblack76 Posted December 28, 2015 Report Posted December 28, 2015 The 320 im getting has a turn on of 650rpm. With the motor you have, i would look for a lower turn on, even if that means giving up some top end. Just my opinion. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
reedal Posted December 28, 2015 Report Posted December 28, 2015 So I got a response back from mechman and he said a 320A Is available bUT won't charge under 1000rpm what exactly does that mean? That for instance if I'm sitting at a light bumping that I will eat the alts reserve then into my battery reserve?Most idle speeds are 600-800, meaning your alt won't charge at idle (at lights).So a alt like that probably won't do the best around town then? I'm really hoping to find something closer to like 270 or 280 that will do well at idle Look into Singer (www.singeralternators.com) or DC Power Inc. as well. Mechman isn't the only option SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Bayuk89 Posted December 28, 2015 Report Posted December 28, 2015 Most people with heavy bass set ups dont demo at idle. They have their throttle turned up with extra throttle cable or hold down the gas pedal till 1500 or more RPM. Do you plan on being full tilt all the time when ur vehical is running ?
Broke_Audio_Addict Posted December 28, 2015 Report Posted December 28, 2015 Most people with heavy bass set ups dont demo at idle. They have their throttle turned up with extra throttle cable or hold down the gas pedal till 1500 or more RPM. Do you plan on being full tilt all the time when ur vehical is running ? He daily drives the vehicle so he needs something with a lower turn on speed or his car isn't going to run properly. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Massivespl Posted December 28, 2015 Report Posted December 28, 2015 Hairpins are where it's at for idle amperage. c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
