Bayuk89 Posted January 16, 2016 Report Posted January 16, 2016 Well i met a guy locally who has a DD1 and we tuned my HU and amp. Put in the SMD cd on track 1 40hz 0 dB my kenwood x399 excelon series puts out 35/35 clean, moved to amp. Guy asked me to change to track 5 40hz @-10 dB. I asked what the difference was he said between SQ and loud. Tuned my amp gain almost 1/2 way before distortion detected. Any who WOW jebus !!!! Bass is so much louder and powerfull i NEED to invest in a DD1 for future builds. So my question is i listen to all kinds of bass synicate, bass patrol, bass meckanic, decaf, DJSNT. Being tuned at -10 dB can i listen to modified music at same volume as regular music ? Or do i need to cut some volume on my sub outs on the deck, i think to goes from -10 to +10 maybe modified music set it at -3 to be safe ? But i though that was the point of using -10 dB @ 40 hz for tuning vs just using 40 hz @ 0 dB was for that "space"
n8ball2013 Posted January 16, 2016 Report Posted January 16, 2016 I tune my amps at -5. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
reedal Posted January 16, 2016 Report Posted January 16, 2016 It depends on the level that the music is at. If unedited music is recorded with sub bass levels at -10dB or lower such as -15dB, then your amplifier being set at -10dB is fine unless the music is already clipped in which case you just shouldn't be listening to it. If it's recorded higher than -10dB (-2.5dB, -5dB) then you need to turn the volume down. And the same applies for edited music. And that is what Steve Meade's OM-1 meter does for you. If it's a higher level recorded song than what you set the gains for, you can damage your subs quickly, but if it's lower, then you're fine, it just won't be as loud as other songs. You should be fine with -10dB for most music, but you can find a clean -7.5dB 40hz track on here to use instead and feel a little safer if you want. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
CleanSierra Posted January 16, 2016 Report Posted January 16, 2016 I set mine to -7.5 dB overlap. Thanks SnowDrifter Im not the one you want to try to troll. Just a fyi for you.
MotorCityFats13 Posted January 16, 2016 Report Posted January 16, 2016 alot of people coincider -10db a pretty radical tune and choose a custom -7.5 at most.... if you listen to special bass tracks just be careful because you might smell something bad.... or try to have it redone with a -5db but you will lose some of the awesomness you were speaking about
Bayuk89 Posted January 16, 2016 Author Report Posted January 16, 2016 I usually just put on dj magic mike or bass 305 on pandora, other than that its just FM radio. He gave the DD1 and walked me through the steps and we tuned it, he never asked but i gave him $20 when we were done. Glade to know im clean 35/35 on my kenwood and have my amp properly set now. Im sure heavy clipping will be noticable, i will listen for negative changes in my bass and just turn the HU down if i hear it or smell the coils getting hot. These subs jump now it crazy seeing them "dance" it didnt do much of that before. I will focus on the -7.5 dB when i get my own DD1, for now i will just listen to how my subs are playing. Im just curious why he wanted to tune at -10 instead of -5 or even zero.
Bayuk89 Posted January 16, 2016 Author Report Posted January 16, 2016 alot of people coincider -10db a pretty radical tune and choose a custom -7.5 at most.... if you listen to special bass tracks just be careful because you might smell something bad.... or try to have it redone with a -5db but you will lose some of the awesomness you were speaking about If -10 is radical why is there a -15 on the SMD cd ? Is that for setting up comp amplifiers on custom made music ?
ShadeTreeMechanic Posted January 17, 2016 Report Posted January 17, 2016 Tuned in. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
reedal Posted January 17, 2016 Report Posted January 17, 2016 There's -15dB because there is an extreme for everything in this world. You could use the -15dB if you wanted, but I wouldn't recommend it unless you have an OM-1 and a PAC lc-1 to turn it down immediately without losing your mids and highs as well. -10dB isn't that radical in my opinion, not for most music. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
DubNDodge Posted January 17, 2016 Report Posted January 17, 2016 for decaf -7.5 djsnt -5 got160s -2.5 normal music that isn't too bass heavy should be chill at -10 '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
