Voltage drop
I have a 99 Chevy Suburban. I bought a rebuilt alternator that is 300 amps I also have a red top optima battery that I bought about 5 to 6 years ago but only used it for about two years of its life I recently installed two sets of Kicker 6 1/2 to a hifonics 600 watt 4 channel amp. My speakers sound great everything is tuned in and dialed in but when I hooked it up. My voltage went from 14 to 12 what could be the problem the ground is clean and the voltage never moves down or up even when I play the music loud it just stays at 12 volts the truck starts up fine so I can't figure it out.
12v according to what meter, measured from what point?
What brand alt?
What's the resting voltage of that battery after the engine has been off overnight?
What's the voltage right off the battery when running.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
The alternator was rebuilt at a shop that rebuilds alternators and starters so it's just a local company that did it as far as the voltage I read it off the dash I didn't put a voltmeter on it or anything. But I was reading the voltage on my dash it was always saying 14 volts and after I hook the amp up I realize that it said 12 volts.
​I had a 99 burban with the same problem. it's the grounds. Redo all grounds (and I hope you did the big 3)
They have to be solid as a rock on that truck.
Also get a true meter.
Optima red top is horrible, and it being 5-6yrs old doesnt help.
Get a new battery.
As mentioned. A 300amp alt better have the Big 3.
I just installed the app yesterday but I was planning on doing the big 3 first thing this morning and tightening up a lot of the grounds appreciate the information I'll do that this morning and see where it takes me thanks.
Either your rebuilt alt is faulty, or your dash meter isn't accurate. I'm leaning towards the meter, but use a DMM to read your voltage with the engine running, with the system off and with it playing.
