Need the pros input real quick.
Wana get another bat for my setup. The audio legion 3500 will be here on the 24th so i want to get another agm batt. I just dont know if i need another xs d3400 or can i just get a duralast platinum battery and put the xs d3400 under the hood and put it in the back with the other d3400. Ive always kept the batts charged up with a ctek 7002. What do you guys think ?
Ideally the same AH rating should be used. I have seen people put tiny batteries in the back and they seem to do something. The XS AH rating might be measured different than the Duralast AH rating I don't know.
Pioneer 80PRS
Should i be fine with a duralast platinum batt? I wanna make sure i have plenty of power for that amp. I also have a mechman 250 alt as well
like audiofanaticz said... as long as they are both agm... you cant use a conventional lead acid with an agm battery they do not charge at the same rated and such... one of the batterys will fail in someway or another
The duralast platinun is agm. Just dont know if it will be good enough for that audio legion amp. 1 duralast platinum agm bat and 2 xsd3400 batts or will i HAVE to go with 3 xsd3400
you can get the duralast, but I would suggest that instead of putting the duralast in the rear with the other XS, put both XS batts in the rear for prettiness, and have the duralast under the hood. Just me. I had a duralast AGM under the hood and an XS in the rear when I had my explorer. Mixing AGM brands shouldn't cause an issue.
I should have picked up on that one... since I have an autozone agm... lol
Shouldn't matter.
