d-nice88 Posted February 28, 2016 Report Posted February 28, 2016 Ok its probly been asked a 100 times but i dont feel like searching the forms im to tired from work ;/ so ill ask. If i got all 3 of my agm batts hooked up in parallel can i charge them all up at the same time if i hook up my ctek 7002 to the bat under the hood ?
magillaru Posted February 28, 2016 Report Posted February 28, 2016 Simple answer is yes like audiofanaticz said but I usually like to charge a group of batteries by (using yours as an example) connecting the pos to battery 1 and the neg to battery 3 (or vice versa) to get an equal distribution across the entire bank. Singer Alternators Team Asshole #anothershittysingerbuild
MrSkippyJ Posted February 28, 2016 Report Posted February 28, 2016 I'd be curious to see if that makes a difference. I asked my stepdad about this and he said it makes no difference. I can't ask him again but I'd still be curious to see the answer. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Wehan Posted February 28, 2016 Report Posted February 28, 2016 This is a parallel charging board for rc cars, the same principal applies and here is how they laid it out. For this product they recommend that each battery be within .2v of each other before starting a parallel charge but it's for LiPo batteries and they really don't like to self balance (not sure if AMG batteries are like this or not)
ShadeTreeMechanic Posted February 28, 2016 Report Posted February 28, 2016 Just hook it to any positive and any negative. Parallel is parallel. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
NorCalMike Posted February 28, 2016 Report Posted February 28, 2016 If all 3 batteries are already wired in parallel, they should all have the same voltage. They will charge/discharge each other until they are all equal. So mismatched voltages shouldn't be a concern, unless you have a bad battery in the group.
d-nice88 Posted March 2, 2016 Author Report Posted March 2, 2016 Ive got 13.57 across all batts (2 xs power d3400 and 1 autocraft platinum ) and man all them batts to the new audio legion amp i got is straight killing my trunk looks like the trunk wants to come off. So satisfied with my purchase and all the help and advice i get from this forum.
