Clownrock95 Posted March 6, 2016 Report Posted March 6, 2016 Like the title says Do the flares make that much diffrence? Is there some applications that favor one over the other? Is it worth flareing some PVC pipe? I know there is a calculator for aero ports on the website would that work for PVC (assuming same diameter)? (System spec if it matters) 2 vcw124 on a nvx 1200.1 the box will be built to the suggested size and tuneing for said subs (unless anyone would like to make a better suggestion)
Hotdog Posted March 6, 2016 Report Posted March 6, 2016 flares make the port more efficient and if you are not giving enough port area Flares will help with port noise. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
shogen Posted March 6, 2016 Report Posted March 6, 2016 flares make the port more efficient and if you are not giving enough port area Flares will help with port noise. exactly.... is it necessary in all situations... probably not but if you can afford to get some PSP ports then you'll be fine Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Markous Posted March 6, 2016 Report Posted March 6, 2016 I have a question, Does the face of the flare to the end of the taper count when measuring port length with aero's? Or is it strictly the tube length that counts? '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
shogen Posted March 6, 2016 Report Posted March 6, 2016 PSP4-BKHT - 4" x 17" unit that includes 1 outside flare with mounting holes, I have a question, Does the face of the flare to the end of the taper count when measuring port length with aero's? Or is it strictly the tube length that counts? 1 inside flare, 2 connecting rings, and 1 plastic tube. 18" overall length with only 17" usable because of the flares on both ends. Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Joe X Posted March 6, 2016 Report Posted March 6, 2016 Like the title says Do the flares make that much diffrence? Is there some applications that favor one over the other? Is it worth flareing some PVC pipe? I know there is a calculator for aero ports on the website would that work for PVC (assuming same diameter)? (System spec if it matters) 2 vcw124 on a nvx 1200.1 the box will be built to the suggested size and tuneing for said subs (unless anyone would like to make a better suggestion) 1) Yes, more so if the port is going to handle high port airspeeds. 2) Aeros are recommended in sound quality applications. 3) Your call, I would just get flares for the pipe. 4) Torres calculator will work fine for non flared aero ports as long as you use only a single pipe.
Clownrock95 Posted May 16, 2016 Author Report Posted May 16, 2016 Like the title says Do the flares make that much diffrence? Is there some applications that favor one over the other? Is it worth flareing some PVC pipe? I know there is a calculator for aero ports on the website would that work for PVC (assuming same diameter)? (System spec if it matters) 2 vcw124 on a nvx 1200.1 the box will be built to the suggested size and tuneing for said subs (unless anyone would like to make a better suggestion) 4) Torres calculator will work fine for non flared aero ports as long as you use only a single pipe. i know its been a while but care to explain this as you can see here i plan on useing 2 3 inch pipes why will that only work for 1 pipe wouldn't you just divide it by number of ports
Triticum Agricolam Posted May 16, 2016 Report Posted May 16, 2016 i know its been a while but care to explain this as you can see here i plan on useing 2 3 inch pipes why will that only work for 1 pipe wouldn't you just divide it by number of ports No, you can't just divide it by the number of ports. That's not how box tuning works. One 3" port 11" long, for example, will not tune you the same as two 3" ports 5.5" long. When you double port area you have increase port length as well to keep tuning the same. If you are only going to use two 3" port for a pair of 12" subs on 1200 watts you might as well just leave the box sealed. With that little of port area, the performance is going to be pretty poor. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
meade916 Posted May 16, 2016 Report Posted May 16, 2016 I have a question, Does the face of the flare to the end of the taper count when measuring port length with aero's? Or is it strictly the tube length that counts? JUST the tube length counts. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
