i was going to say 15.2 is not really anything to be concerned about but your meter looks like its getting close to 16vdc.... when the alt is working hard its pretty normal for it to drag the engine down 200-400rpm but as you said the higher output alt does not do this and that is because there is more power on tap and it does not have to work as hard.... all I can think is there must be a bottle neck somewhere in the charging system.... take a DMM and probe it everywhere you can and find where it gets the largest voltage drop.... you might also have a weak cell in a battery causing it to drain faster and it wants to charge more and the alt is over driving?
with a smaller rms system you should have no problems with that large of an alt and the wiring you have installed
check what your resting voltage is after it sits for 12+ hours
There is definitley a bottleneck at the RF one to two 0/1 splitter as it enters the cab, something i have to correct for sure.
Thanks for the help MCF, i will poke around with the fluke to see if i can find a cause.
It was sitting at 12.8 when i got in it this morning, about 10 hours after it had been running last.
eta- i forgot to mention i was idling at 1.8-2k when i shot that video
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
What i'd start with, is checking the resistance of all the connections with a quality ohm meter. just probe on both sides of each connection and check for anything out of the norm.
The internal regulator may have something weird going on.
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
This will look quite nice in place of the 50.4 B) should make the EQ'd SA-6.5CX's sing nicely (when i get them installed and get an EQ that is)
Test fit some 2 guage on the inputs and it fit's nicely minus 10-20 stands that wouldn't co-operate.
Now you five play nice together :friends::yahoo::friends:
Yea, that's getting close to 16, that's hard on equipment made for 12 volt system........
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
like i mentioned before, and thats what confusing me is that rock and alt make it bounce between 13.7 and 15.2
Heavy beats make it start to spike around 75-85% volume
i will e-mail mechman a link to this thread see if they can help.
kinda guessing i might but i haven't protected the 2k, it must be quite brief.
The light dimming being worse after the work i did is also disapointing to be honest
Yea, sorry, i have no idea but curious how it turns out.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Is your trucks alt internally regulated?
Not sure to be honest, there is one connection from the main harness that fed back into to another single connection on the old alt. i did need to make and it has been tied back.
Told it was done internally now, guess thats what you are talking about?
