Running your subs on more then rated power
KillerKeller40
Personally, the line is drawn by knowing your own equipment. Knowing you mechanical limits, thermal limits (knowing when to back off, whether you smell the coils heating up, dustcap gets warm/hot), and how your box plays given frequencies.
There many dyno videos and like most amps TS sends a test page of what they got on that amp at what voltage. And yes the amp is rated 2.8k on your typical 12.8-13.3 electrical system but like I said at 14.4v it will do easy 3500 @ 1ohm
The only way to know for sure what your woofer will see is the clamp it ;-) Your electrical needs to be adequate for the amp to actually make the said power output. Like the others already said, many variables exist. Type of music, is the signal clipped or not, how long are you playing the music at any given time, etc etc etc....
I've ran many many speakers with way more 'intended power' than the RMS rating of the speaker, and never have problems. And yes, if you push the speaker to it's limits often, it will wear out faster.
You guys are thinking way to hard about this, I feel. If the gains are set correctly, all you have to watch is mechanical (make sure it doesn't bottom out/jump the gap) and monitor heat under whatever power is applied.
If you have quality soft parts, other than break in early on, as long as it is kept within its limits, it shouldnt ever "wear out".
Clamping an amp that is playing a sub will always show more power than is actually being applied because the voltage and current are not in phase with each other. One way to get a true measurement would be to clamp it with a resistor bank instead of a sub.
Pioneer 80PRS
Amm-1
with a 4.75 cu ft box ur box rise is atleast between 3 n 4 ohms(just guessing cuz its a big ass box), my box is same size tuned 38hz runnin hcca 12.2, bigger boxes are for if ur gona under power the sub, the bigger the box the less power ur sub will handle, get a slightly smaller box and buy an amp thats rated atleast 2000rms at 4 ohms lol good luck
06 Envoy
250a ALT
2x 2400 kinetiks
USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122
Taramp HD2500 for mid range
4xPioneer 6x9's 2x 1" Pioneer tweets
Who would do such a thing
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1505 Guests (See full list)
