the_garynator Posted September 14, 2016 Report Posted September 14, 2016 Just curious if anyone knows of any parallel[\b] 6th order bandpass walls, or even no wall builds. I'm currently building one and was wondering if anyone else has. And I'm not talking about series tuned (rear chamber ported into front) which all of the 6th orders I've seen are. Thanks! Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx
rocking.that.eclipse Posted September 14, 2016 Report Posted September 14, 2016 NoSami ran one for a while. Not many people do it because they are a little more touchy than the normal series tuned. I know that you want to keep you ratio as close to 1 to 1 as possible.
jk13 Posted September 14, 2016 Report Posted September 14, 2016 Saw one on here recently in a wall, and there are pics of a few others running around. Can't remember specifically who built them. I've built a few trunk/hatch boxes over the years, one from 1991 that is still running around today that my friends named the lunchbox. Issue with a wall is that if you're chasing numbers it's very difficult to align multiple ports at multiple frequencies to the mic placement point. Have seen a couple great demo setups though. Static drops are my bag.
the_garynator Posted September 14, 2016 Author Report Posted September 14, 2016 Hmmm, I'll have to keep searching then, if you run across any links please share. Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx
the_garynator Posted September 14, 2016 Author Report Posted September 14, 2016 Found one http://www.stevemeadedesigns.com/board/topic/169313-bassmondeo-build-digital-designs-8-15s-18kw-parallel-6th-order-wall/?fromsearch=1 Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx
ShadeTreeMechanic Posted September 14, 2016 Report Posted September 14, 2016 Someone is about to get the ban hammer. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
DLHgn Posted September 14, 2016 Report Posted September 14, 2016 He did it in another thread I'm in too. I reported both.
