Dangers with going "too big" on Big 3?
Just got my mechman 240 in the other day. Im about to order some ofc power wires. Im wondering if there is any down side to using 4/0 awg wire right now for my big 3-4. I know 1/0awg seems to be the norm for a good upgrade. But then i see some people say to run multiple runs of 1/0. Im sure i wont need more than 1/0 in the near future, BUT i do like having the ability to upgrade if i wanted to, without having to re-run more power wires. I figure i could just run all 4/0 now, on the big3-4. Then have a distrubution block setup also so whenever i need more power i can just easily tap into that distrubution block. Im just wondering if there are any cautions to using over sized wire BEFORE its even needed.
Also, how does the wire sizes break down when distributing power. Like if u have a single 1/0 input to a power block, can u run two 1/0 output from that power block, or even three out puts of 1/0? If not, how many 4awg outputs can come from a single 1/0 input power block? Thanks everyone, I appreciate yall passin on the knowledge to noobs like me.
A big 4 with 4/0 won't hurt anything. With only a 240a alt it's not needed on the alt. But if you already have it for other things then you might as well. 4/0 is a pita to run and get in tight places because it is so fat. It might be hard to get behind the alt. Some vehicles don't have much clearance there.
Pioneer 80PRS
Very good point, ill check that before i order the wire. I prefer overkill techniques. Crappy thing too is that my cars battery is in the trunk, the positive to alt is gonna be a pita. Thats another reason i was thinking of doing 4/0 cuz the run from batt to alt is so long.
It's cheaper to do multiple runs of 1/0,
Fuse holders for big ass wires are not cheap at all, nor are distribution blocks, or lugs, or anything else that goes along with it.
Aren't you doing an Sq build?
Also, it's not a crappy thing that the battery is in the trunk,
It's actually beneficial to have the battery closer to the amps.
Sucking $ out of your wallet.
Lol true, when i spend more i try to be smart about the purchase. As long as it gave me the option to upgrade my system easily later IF i wanted, then its worth it to me. Preparation is always nice.
Thats a good point, i didnt even look for a 4/0 block yet. But i was planning on going with knukoncepts kolossis. I only seen terminals in 4/0 if i remember correctly, all their blocks only went up to 1/0. Can you reccomend a site where i could check prices on 4/0 blocks and fuseholders? If its outrageous ill look more into maybe just 2runs 1/0.
  • Who's Online   0 Members, 1 Anonymous, 4182 Guests (See full list)
