nkrell11 Posted April 7, 2017 Report Posted April 7, 2017 Looks like you nailed it on this attempt man, the little extra time is worth it. Current Build: 02 Jeep Grand Cherokee Build (AKA Project Silent Night) Mechman, Neo Slow
BP1Fanatic Posted April 7, 2017 Report Posted April 7, 2017 Yeah he did! Can't wait to see the finished product. 2011 Ford Crown Vic LX, LActrical 240A alternator, A6 Pro, Orion Cobalt CBT.3500.4, 2 CO652C's, CBT.4500.1, 8 JBL GX1200's in an Isobaric BP4.
WalledSonic Posted April 10, 2017 Author Report Posted April 10, 2017 Cut my second door baffle today Glued two of my kerf boards together After screwing around with clamps for a bit, decided to just trace the face board and make a jig for the kerfed box walls Lots of PL later... My little helper. SO fucking delicious. It'll be fully dried up tomorrow Snug in the jig Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
WalledSonic Posted April 10, 2017 Author Report Posted April 10, 2017 I cut the cabin vents out a few weeks ago and blocked them up. I quickly realized that you cant block these completely. Air needs to move through these when your windows are down on the freeway: Friday I picked up the custom "Moisture Accumulator/Separator" I ordered for my cabin vents. They allow air to pass unrestricted (mostly) and they have a 98% moisture capture rate. I need to connect a drip line for a drain. More on these soon Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Karkov Posted April 10, 2017 Report Posted April 10, 2017 Kerf looks amazing dude, keep up the great work. Sucks about roof but yea thats what happens when you foam a lot at once. =( Its solid tho so..... gratz on name change 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
WalledSonic Posted April 12, 2017 Author Report Posted April 12, 2017 Finally found a use for my lead acid battery. Inside view, face board is glued on. All wood and glue at this point. Gotta love that flush trim bit Followed up with a 3/8 roundover Ended up using the 1/2" roundover, a bit shallow until i do the final touches The Silver Flutes will fit. One fits over where the 6.5" is located and the other will fit about where Im holding it below Need to jigsaw each pod little by little so the back face contours to the door. One more look before I get the pod fitted up. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bcbrassard Posted April 12, 2017 Report Posted April 12, 2017 Damn dude.... thats going to turn out sick. Hats off to your killer design!
BP1Fanatic Posted April 12, 2017 Report Posted April 12, 2017 That cameout purdy! 2011 Ford Crown Vic LX, LActrical 240A alternator, A6 Pro, Orion Cobalt CBT.3500.4, 2 CO652C's, CBT.4500.1, 8 JBL GX1200's in an Isobaric BP4.
WalledSonic Posted April 13, 2017 Author Report Posted April 13, 2017 Freehand jigsaw action The final cuts are close fitting Mock up Now I can install the door panel, reach thru the speaker holes, then trace the shape of the box onto the door. Then more custom cuts and rivnuts, then lots of deadening. Its coming along though. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ShadeTreeMechanic Posted April 13, 2017 Report Posted April 13, 2017 Pods look killer! Are you going to leave the back of the pod open to the door or is there going to be a back panel? Tuned in for more. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
