BMS Posted December 1, 2016 Report Posted December 1, 2016 looking for a pair of bullet tweeters was looking for recommendations I like the idea of pride audio but they say they are 20-30 watts i'm a little confused by this. I know that the power handling depends n the frequency and rang but they don't give any of that info and how some other brands are rated at 150-200 watts i cant imagine that being accurate unless they mean to say if the amp putts out 200 watts full range you can use the on that but they maybe get 5-15 % of that 200 watts because it is only the high frequencies.
BMS Posted December 1, 2016 Author Report Posted December 1, 2016 112db sensitivity is that possible? http://www.kromeloudspeakers.com/products/tweeters/
ShadeTreeMechanic Posted December 1, 2016 Report Posted December 1, 2016 I have never heard a set of bullet tweeters that I would want to sit next to. If you are just trying to get loud, I'm not sure if there is much difference sound wise. A metal dome tweeter is a metal dome tweeter. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Broke_Audio_Addict Posted December 1, 2016 Report Posted December 1, 2016 I like none of them, just seeing them makes my ears hurt. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Soccerballzs Posted December 1, 2016 Report Posted December 1, 2016 None. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
crownvictoria31 Posted December 1, 2016 Report Posted December 1, 2016 i have 2 of the Lanzar TCP22 super bullet tweeter on my rear deck with 4 10" PRV mids. They get real loud and the clarity is very clean. Very very clear bullet tweeters. They are big though but work great.
ShadeTreeMechanic Posted December 1, 2016 Report Posted December 1, 2016 Crown Vic how much power does it take for them to get loud? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
White Lightning Posted December 1, 2016 Report Posted December 1, 2016 None.Same here. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Keith77 Posted December 1, 2016 Report Posted December 1, 2016 MY EARS ARE BLEEDING Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
crownvictoria31 Posted December 1, 2016 Report Posted December 1, 2016 I am running them on a Rockford fosgate r600x4d which is 100 watt rms per channel. I have each tweeter running on both front channels. Amp is set alittle less then half way. They are real nice tweeters. They don't make my ears bleed and sound real clean.
